What is best way to paint/coat new BIG table tub
We are building a 11'x60' table and wanted to know what is the best way to coat the inside tank. What do you guys put on the tank to prevent rust and if you paint the tub does it affect the ground.
Re: What is best way to paint/coat new BIG table tub
I use a rustoleum plus hardener and stray the tanks, slats, supports, and frames on the table I built. works great
https://www.youtube.com/watch?v=2uMmNFOH6EY
I also clamp directly to the metal being cut with the Plasma work lead.
I'm getting ready to build a new water table myself and I'll be using a two part epoxy paint.. getting it free from a friend that is a contractor through a company that builds and repairs water tanks and towers..
