Files problem
Files problem
Hi! Ive recently down loaded Alibre Design and now all my files have the alibre symbol in front of them where they used to have Corel draw so now they always want to open in Alibre but most of the time I want to open with Corel I'm wondering how to change it?
- lockeyone
Re: Files problem
type in "file associations" in your widows search. It should tell you how to do it.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
Re: Files problem
This might not be relevant since I use a Mac, but if I go to my files area and right click and hold what I want to open, I can choose what program to use. I use Illustrator to trace JPEGS and I can use any of my image programs to open them such as Inkscape, photoshop etc.
Re: Files problem
that problem is not only Alibre's but most of image type programs in Windows, when you install a new program they feel they have the right to claim all images on your system as theirs. As Lockeyone said it is easy to fix, find an image and right click on it. This brings up a menu scroll down to "properties" then click on change under open with and click the program you want to use, and be sure to have use for all file like this.
Re: Files problem
Thanks to all of the above! solved the problem! acourtjester how do you do the screen shots with annotation? I always admire your descriptive posts!Allan.
Re: Files problem
I use a program called HiJaak Photags Express it is a IMSI software package. This is the only one I could find on the web at this date.
https://www.ebay.com/itm/Hijaak-Digital ... 2526!US!-1
Re: Files problem
Thanks! It does look like the latest windows version its rated for is XP. I wonder if it runs on 8 or 10?
Re: Files problem
I'm using it on win 7 just fine, I hate 10 so the last pc I bought sits idle as it has 10 on it
