Hopefully someone has some ideas or answers or maybe it's just normal?
So today I was cutting a fairly large sign out of .250 plate and is was a total of about 15 minutes of cutting and 6 pierces. Everything was going great until the last maybe 10 inches then the electrode blew out and cup has a huge hole in it and it sprayed copper all over the steel. They were brand new when I started the cuts.
I'm running 60 amp 42 ipm on .250 plate if that matters?
I have had this happen before but I do mainly small runs or one off parts so dont really know my consumables lifespan.
I have a homemade plasma table with a everlast 80s plasma with 100 amp machine torch using 65-70 amp consumables and a proma thc. Maybe the consumables are just junk? I dunno but I would think I should get more than that out of them. I have been buying them from plasmadyn.
Tips and electrodes blow out after 14 minutes of cutting
Diy 5x10 plasma table
Everlast 80s plasma Everlast 250 tig
Lincoln 350mp mig
Bridgeport series 1 and 2
Webb 3vh vertical mill
Brown and sharpe horizontal mill
South bend 14.5 x60 metal lathe
Old 65 ton piranha iron worker
Lincoln 350mp mig
Re: Tips and electrodes blow out after 14 minutes of cutting
Are you sure your compressor is not building up water? I drop of moisture will cause that in a heartbeat.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
Water in the air lines was my first thought too
I get about 1000 to 1500 starts at 65 amps with my plasma. I have never had an electrode or nozzle blow out, rather I change them when the cut quality deteriorates. Though I paid more up front for the Powermax plasma is cost me a lot less to use.
Almost alway water. sometimes it could be a shorting from the material but most likely water. I do not have a refrigerant dryer but I use three stages of dry rite descant that I can change out and re dry. For the most part, it has worked well for me over the years.
Most likely water .
Id agree most likely water in the line.
Buy an air dryer, it was the best think I ever did!
I agree with that comment and also suggest that you buy the best one that you can justify/afford that will properly handle the cfm flow at pressure of your compressor. I have a refrigerated dryer at the compressor and also have a 4 stage desiccant dryer just prior to the plasma machine air supply. The desiccant has not been changed or reactivated in over a year and it is still blue (showing 0 moisture in the lines). I also live in humid South Florida which previously played havoc with my consumables.
4' x 4' DIY Table
CandCNC Bladerunner
Miller Vintage 250 Mig
Miller Syncro 180 Tig
Bridgeport 2J Mill - Fagor Dro
Southbend 14" x 40" EVS Lathe - Fagor Dro
Brook 18" Metal Shaper
Harig 612 Surface Grinder
CandCNC Bladerunner
Same here, I have a moto filter (looks like a toilet paper roll) at the machine 25 feet ahead of my refrigerated dryer, its been a year now and the paper roll still looks like new!
