Magnetic Chuck for grinding
- ColoradoWayne
Is anyone using a magnetic chuck for hand grinding? It seems like it should hold material really well? I am curious to learn how people are using these magnets.
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
Re: Magnetic Chuck for grinding
I have seen videos of guys using what you are talking about on 2X72 inch belt grinders
https://www.youtube.com/watch?v=8sOygo8w2h0&t=227s
- ColoradoWayne
I am thinking just to hold down metal while using a regular hand grinder. I just don't hear, or see, many folks using them and think there may be a good reason not to use them?
Wayne
Magnetic chucks can be hard to find or they cost to much when you do find one. I bought a few rare earth magnets that were 1/4" thick and 3/4" square. I just put some down on my metal top bench in the configuration I need for whatever I am cleaning up and grind away. works great.
- ColoradoWayne
That is what I was hoping to hear. Do you put the magnets under the table to hold your work piece? That is what I am hoping to be able to do. Less expensive magnetic chucks (under $100) are available on ebay with several hundred pounds of pulling pressure.
Wayne
I bought a cheap one off of eBay and built a table for it to sit down in so the top is flush and that is one of the many best ideas I have gotten off of this forum. After I done that I realized just how much dust I was breathing because I started doing all of my grinding in one spot.
This is something like I bought. I know its probably not the strongest one out there but I would buy it again in a heartbeat.
https://www.ebay.com/itm/100N-120N-Surf ... 0005.m1851
I also saw the idea of the magnetic chuck for grinding here on the forum several years ago and built one into my grinding table soon after. The increase in production alone more than pays for the cost of a chuck in short order. Grinding makes the most dust in my shop, so I plan to build a vented grinding table next and it will have one or more magnetic chucks built into it. The chuck holds large items well, but really is outstanding for holding several smaller items at a time. I have gotten many good ideas from the forum but this is one of the best.
- ColoradoWayne
Any chance you guys, blackandtan and Healeyfishing, can share a picture of how you did your table and mounted your magnet? There is very little on here about these and you two certainly proclaim these as truly beneficial. I hadn't thought of the additional value of it grabbing the dust too.
Last edited by ColoradoWayne on Sun Dec 09, 2018 10:50 am, edited 1 time in total.
Wayne
I will try to get a picture tomorrow.
- tnbndr
So, how do you go about cleaning off the magnetic dust from grinding?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- ColoradoWayne
These magnets have an on and off switch, I am assuming you turn it off and just wipe it down. Hopefully those that are using them can share their experience. I think I will order one today and see how it works out. I would like my magnet to be contained so it doesn't get dirty. I am hopeful you can put the magnet under the table and it is strong enough to clamp the material through the metal table top.
Wayne
I would be surprised if it would hold through the table top. Here is how I done mine.
- ColoradoWayne
Thanks, I hope I can get it to work through the top, but if not I will do the same thing you did.
Wayne
Thant looks super handy. Thanks!blackandtan wrote: ↑Tue Dec 11, 2018 9:55 pm I would be surprised if it would hold through the table top. Here is how I done mine.
Brilliant! Thanks for the info guys, gotta build one into my bench. Love this forum!!!!!
- ColoradoWayne
I just got a magnetic chuck table top put together. Only sanded one piece and it made a huge difference. Both hands on the grinder, no clamps to hit, and a lot of the dust just stuck to the magnet. Just turn the magnet off and wipe the table top down. Using a fine pole magnet it appears there can be nothing between the magnet and the work piece. I don't know what would happen with a coarse or normal pole magnet? So far I am quite pleased with this experiment.
Wayne
Definitely going to do one of these!
Here is my red neck magnetic chuck. 4 magnetic tool bars, available at most hardware stores, bolted back to back. Stick them down any where on your work bench for small or large work pieces. I stick them on the end of my lathe when not in use.Also shown is my angle grinder with my favorite wire cup brush. Makes short work of dross on the backside of cutouts. I almost never use a grinding wheel on work thanks to my PM 65 plasma cutter and candcnc electronics. Same wire brush cleans magnets off when needed.
- tnbndr
So I am assuming only the top is magnetized when on?? or will it hold to a metal welding bench when turned on?ColoradoWayne wrote: ↑Tue Dec 18, 2018 9:44 pm I just got a magnetic chuck table top put together. Only sanded one piece and it made a huge difference. Both hands on the grinder, no clamps to hit, and a lot of the dust just stuck to the magnet. Just turn the magnet off and wipe the table top down. Using a fine pole magnet it appears there can be nothing between the magnet and the work piece. I don't know what would happen with a coarse or normal pole magnet? So far I am quite pleased with this experiment.
- ColoradoWayne
Only the magnet itself has magnetic pull, not the whole table. Yes, only the top is magnetic. This only works well on thin material, the magnet has very short magnetic reach. I've been using for almost a year now and it has truly made my work much easier.
Wayne
This reminded me of the DIY electromagnet topic by Scrtach viewtopic.php?f=85&p=173030
Still gotta do this sometime myself but I thinks its genius for anyone wanting a magnetic grind table.
