Air Compressor Oil Weight for cold weather?
My compressor is in a unheated pole barn in Michigan, I noticed it starts up somewhat slow when cold, should I put a lighter weight oil in it like maybe 20 wt? just wondering if anybody else has this problem?
Re: Air Compressor Oil Weight for cold weather?
If your running a straight 30w try going to a 5w30 synthetic motor oil. I just use Mobil 1 synthetic and compressor starts easy in the cold. My shop would be a little warmer than a pole barn but this should help.
- Desertdog
I use one of these Wolverine heaters with a thermal cube. They make different sizes and wattages for your application/location.
https://www.wolverineheater.com/collect ... 5118636434
https://www.wolverineheater.com/collect ... 5118737810
Westcott Retro 5x10
Design2Cut software, CAD, CAM, CUT, all in one program.
Hypertherm 45XP
Champion 2 stage compressor, 7.5 HP motor, 15 HP pump (QUIET!),
80 gallon tank, auto tank drain, mag starter, after cooler.
25.8 CFM@175
Hypertherm 45XP
25.8 CFM@175
It doesn't get too cold here in central NM, but I have a cheap and simple "Auto Zone" engine block heater mounted right on the crank case.
I also found that my belt was lose...what a difference that makes!
I know this is an old post, but I am looking at this same compressor, how has it worked for you? Is this the reed or disc valve version? Have you had any problems with it?Desertdog wrote: ↑Mon Dec 03, 2018 12:59 pm I use one of these Wolverine heaters with a thermal cube. They make different sizes and wattages for your application/location.
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
