mach 3 or sheetcam
kennye
mach 3 or sheetcam
Post by kennye »
I recently had a computer to go on the blink and had to replace it The problem I have is withe the settings in sheetcam or mach 3 don't know which one
I've had a heck of a time trying to get my configurations right in mach . Normally when I cut I moved the torch to where I want to start I clear out my xy and z settings hit jog to start .The problem Im having is the part I want to cut is on the opposite end of the table in The display and the torch crashes before i get to my cut .I appreciate any help maybe someone else has had this problem
would my problem be in mach 3 or sheetcam Thanks
Re: mach 3 or sheetcam
First I would check to be sure you are set up for inch in Mach if that is you units of measurement. the next this is be sure that in SheetCam you have your drawing loaded in the lower left corner of the display. There are 3 locations where this is checked under OPtions in Job and machine pages, and when you import a drawing.
kennye
Post by kennye »
Thanks I appreciate the help may be with that I can try to get my torch and everything config I know one thing when I do everything will be documented so I wont be caught with my britches down again .thanks you a good guy
