Would like to build an arm to support my torch cable overhead I have some ideas anybody have any good pics or designs they used?
Thnaks
ed92254
Torch Overhead Support
- Ironken
Re: Torch Overhead Support
Here's what I did on my old machine. A couple swivel clips, key ring, and some conduit hangers.
I really like how my premier plasma is set up. If you can find one of these flexi things. Maybe call Jake at PP.
Cable chain. You can buy different sizes online.
Attached is an image of a torch cable support I have used on about 4 tables I built, the end pivoting section is a must to allow the cable to cover the extreme reach to the 4 corners.
- WyoGreen
Here's a picture of my overhead torch cable support. It's a bit confusing because the table is set up for laser engraving right now so the magnetic torch mount is just stuck to the Z axis motor for the picture. But basically it's just a length of 1 inch conduit with the torch cable routed thru it. It rotates on a ball bearing mount on the side of the table.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Thanks for the ideas guys
