It is currently Tue Oct 16, 2018 12:13 am
Newbee downloading files?
Fatbastard
Postby Fatbastard » Sun Jun 10, 2018 3:50 pm
Im new to all this, How do I down load files to cut ? When I down load file it wont open? Im running Inscape, Sheetcam and mach 3 on my wright 4x4 table.
Thank you
Chip
WyoGreen
Re: Newbee downloading files?
Postby WyoGreen » Sun Jun 10, 2018 5:49 pm
It sounds like you are getting the .dxf file to download. (You can't open the .pcm files you find on here unless you have a plasmacam). In Sheetcam you "import" the .dxf file. Not entirely sure about Inkscape, but it's probably an import too. (That's instead of "open file"
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
CNC Router table
Fatbastard
Postby Fatbastard » Sun Jun 10, 2018 5:59 pm
HOW DO i GET IT TO SHEETCAM ?
Postby acourtjester » Sun Jun 10, 2018 8:16 pm
SheetCam operates like most windows programs you click on "Import Drawing" and it opens up a folder on the disc. You may need to navigate to where you have stored the file, you also need to ID the type of file (DXF or SVG) it only displays one type at a time in that location. Click on the file you want to import, now for SVG it will give you a ration 1:25 you need to change it to 1:1 to match the original size. You can do a different ratio if you want to increase its size. Or you can click on custom and select what you want. SheetCam also give you the option of where to display it on the screen, lower left may be the most likely, just click to position the dot for location.
Everlast PM 256 tig
BanksAg
Postby BanksAg » Mon Jun 11, 2018 3:30 pm
Here are some good videos on working in Sheetcam from Arclight CNC's website: https://arclightcnc.com/sheetcam-tutorials/#
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Users browsing this forum: norr2009 and 5 guests
