It is currently Thu Oct 18, 2018 10:51 pm
Cut path problem
Post your questions or tips on Plasmacam software in this topic.
michelle
Cut path problem
Postby michelle » Sun Feb 11, 2018 2:23 pm
Can someone explain what is happening with these cut paths? We recently upgraded from 3.11 so we haven't seen this issue before. Thanks!
Michelle
RESERVE GERT.pcm
rdj357
Re: Cut path problem
Postby rdj357 » Sun Feb 11, 2018 5:20 pm
If you upgraded you should have advanced design - go to the offset/convert tab and make sure you have exclude crossovers checked. Also double check your kerf setting, for most thin gauge materials that I'd expect to see these cut from, it's close to .045 - be sure to enter the whole kerf, unlike 3.11 it will automatically only offset half the kerf distance.
I cleaned up the paths a little, the E has a loop on it that's in the font so it should be trimmed off and relinked.
RESERVE GERT Revised.pcm
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
michelle
Postby michelle » Sun Feb 11, 2018 5:49 pm
That's exactly what it was! Thanks so much for taking the time to help me!
rdj357
Postby rdj357 » Sun Feb 11, 2018 5:51 pm
No problem, any time!
Robert Johnson
viebrocj
Postby viebrocj » Mon Feb 12, 2018 1:05 pm
Robert,
Thank you so much. I found you Youtube videos this morning. I have been having this same type of issue. I appreciate your help. Is there a chart somewhere that provides reference examples for settings? I had a chart previously for the 3.11 software, but I cannot find one for the new Design Edge.
Best Agricultural Regards,
Johnny D. Viebrock
rdj357
Postby rdj357 » Mon Feb 12, 2018 5:01 pm
Johnny,
I'm not sure there is a reference and I've been trying to have time to make the next video and that's going to be the exact topic. As soon as I have some of these 'fires' put out I'll get it done and should be a help!
If you're talking about things like I cut height, speed, etc. then the best place to get those is the cutter manual. If you have other questions or need a point of reference, feel free to shoot me a text at 918-457-0289. If a phone call is better then let me know and I'll try to get to a stopping spot where I can take your call!
Robert Johnson
Return to “Plasmacam Software”
