My Horizontal Material Storage Solution
johnp
Post by johnp » Mon Nov 13, 2017 2:08 am
Not sure if this will help anyone else out, but maybe it will inspire some ideas at least.
I was faced with the same challenge many of us are with regards to the need to store large sheets of materials. I needed a way to store multiple sizes of sheets (16ga, 3/16th" 1/4", etc.) which would allow them to lay nice and flat, while also keeping sizes separate and facilitating the ability to load material onto my flatbed as needed.
What I really wanted was a BigSteelRack! Alas, God only knows how much those must cost.
So instead, I purchased a used super heavy duty set of single sided heavy duty cantilever storage rack, and then set out to fabricate heavy duty forklift-able steel pallets to store the sheet material on.
Here's what the steel pallet looks like. I'm actually going to add a couple more center cross braces on the bottom to help support the pallet when laying on the shelving. But otherwise it seems to work well.
With thin material like 16ga, it obviously droops badly on the forklift but when I lay it on the pallet it just smooths right out quite nicely.
Finally, I forklift the pallet onto the arms of the shelving and we're done!
If anyone has any suggestions for improvement I'm all ears! Otherwise, hopefully it helps someone down the road.
Texas Metal Works
My Toys:
MPN Signs
Re: My Horizontal Material Storage Solution
Post by MPN Signs » Mon Nov 13, 2017 3:08 am
Great idea. Very clean looking shop as well!
bigcreek
Post by bigcreek » Thu Nov 16, 2017 1:29 am
Dang man that is one clean shop! Those racks are great for storing material
johnp
Post by johnp » Thu Nov 16, 2017 9:43 am
The shop is super clean because I just built it. :-)
Texas Metal Works
My Toys:
abcofab
Post by abcofab » Fri Nov 17, 2017 5:45 pm
Do you know what the weight capacity of the racks are?
Omax 80X Waterjet 6 x 12 with Tilt-A-Jet
CamFive 150w Co2 Laser
Miller Mig & Tig
Whitney-Jenson 20 ton Punch Press
Atlas Lathe
johnp
Post by johnp » Fri Nov 17, 2017 5:57 pm
abcofab wrote:Do you know what the weight capacity of the racks are?
5,000lb per shelf. Of course that assumes it's all bolted into the floor correctly and stuff. Personally I'm never going to load it up that much, but there are 3,000 lbs of material on the rack at the moment and it doesn't give a.... :-)
Texas Metal Works
My Toys:
bryancab
Post by bryancab » Mon Nov 20, 2017 7:26 pm
gotta be the cleanest shop ever very nice set up
ABLE CUTTING & FABRICATION
torchmate 4800
BATON ROUGE, LA
comeoutswingin
Post by comeoutswingin » Tue Nov 21, 2017 12:08 am
Who built the racks.. I'm looking for exactly that for my new building...
5x10 LDR
johnp
Post by johnp » Tue Nov 21, 2017 12:43 am
comeoutswingin wrote:Who built the racks.. I'm looking for exactly that for my new building...
I got them used. But check my link in the original post...
Texas Metal Works
My Toys:
wobbly one
Post by wobbly one » Tue Nov 28, 2017 5:31 pm
Very nice looking setup John. We recently faced a similar need to store our flat materials on hd storage rack and made racks from 3" angle and 3" x 6" tube. Your cantilever system looks pretty slick.
