Hi Folks,
I've been searching for a cheat sheet if you will, of the hot keys or key board commands for a flashcut controller. I recently purchased and recieved a fab-cut 5x10 (very pleased so far) but i want to run it with a gamming style controller, which i already have. But to map the controller i would like to have a hot keys list. Does anyone have one, or know where to find one? Niether flashcut or fab-cut have them listed.
Flashcut hotkeys
- 5.5 Star Elite Contributing Member
Re: Flashcut hotkeys
The hot keys are intended to be used as a shortcut for various machine operations. FlashCut does not recommend it for productions because it adds another layer as each keystroke is translated to a machine command and sent to the CNC controller. FlashCut and their OEMs/distributors offer a Joystick pendant which gives direct machine commands to the controller per joystick moves or keyboard presses. A gaming console is not recommended for regular use as it does keyboard emulation which is not as reliable as direct machine commands.
Here are the CNC shortcuts:
Here are the CAD/CAM shortcuts:
You do not have access to view or download this file.
Become a Contributing Member to gain access to this feature. Click Here
Thanks for providing those! Hopefully the OP will be back soon to check them out.FlashCut CNC wrote: ↑Wed Feb 09, 2022 10:59 amHere are the CNC shortcuts:
