New person
New person
Hey kids, I'm new here and just saying hey. I've built myself a diy plasma CNC rig running GRBL through an Arduino. I use a Vipercut 301 and whenever I look up issues I have it sends me her so I figured I better jump in. Thanks for having me.
Re: New person
Welcome aboard! I built a small cnc routing/engraving/plasma cutting table several years ago running with GRBL/Ardiuno and it works great. Lots of fun! Show us some pictures of your setup, and some of the projects you are making with it. I was using Candle for communication with the Arduino and Fusion 360 for cad/cam. What are you using?
Re: New person
Welcome Batchain puller!
Slick build David! So many cool details to zoom in and try to figure out. I love it!
Re: New person
I'm guessing I have to use image hosting to post pics?
Re: New person
No - just upload your jpeg images to this site. Click on the "Attachments" button below.Batchain puller wrote: ↑Mon Jan 17, 2022 3:57 pm I'm guessing I have to use image hosting to post pics?
Re: New person
That's handy that you've got in mounted in that suitcase style enclosure. Keeps it protected and easy to move around.
Re: New person
I'm having trouble posting more pics. It says "It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct." If you check on Dac Vu's channel on YouTube, you can see what I built. I bought the plans from him.
https://www.youtube.com/c/DacVu
Re: New person
Did you buy his kit of build from scratch using his plans? I think this looks very interesting.
Re: New person
I bought the plans and a partial kit. He didn't have any full kits available at the time. I think I got the x and y axis, the legs and the motor mounts. It has it's limitations but it is portable and it cuts smaller thing just fine. I am in the process dialing everything in so it's a work in progress still.
Re: New person
usp=sharinghttps://drive.google.com/file/d/1gt00i0 ... sp=sharing
Its pretty hillbilly but it works.
Re: New person
I clicked on your link and it says Google will send me an invitation to view your photos or video. You can go to Google drive and use the "share, copy link (anyone can see it) to get a link that will open directly to post here. That will make it much easier for folks to see your share.Batchain puller wrote: ↑Mon Jan 17, 2022 11:35 pm usp=sharinghttps://drive.google.com/file/d/1gt00i0 ... sp=sharing
Re: New person and I am stoopid
Those work fine. Thanks for sharing your photos and video. It looks like it works very well, and would be a nice tool to have for portable use.Batchain puller wrote: ↑Mon Jan 17, 2022 11:44 pm try these
https://drive.google.com/drive/folders/ ... sp=sharing
Re: New person
Batchain that will get you started, I used my first table to be able to develop and cut DXF files for the newer table parts. For you understanding direct drive steppers do not allow you to get the precision cutting you could have with about a 3:1 ratio. You are still a great leap ahead over hand cutting. I am not trying to rain on your parade.
Have fun
Tom
Have fun
Tom
Re: New person
How does one get a 3:1 ratio exactly?
Re: New person
gears or pulley/belt combo. Or maybe a small gear box/stack.
Re: New person
Here is my "Y" drive assembly Small motor pulley, larger on the auxiliary shaft to drive gear. basically motor turns 3 times to shaft 1 turn.
Batchain PM sent from here.
Re: New person
Build update. The bottom rail developed a sag. I made an adjustable support and that helped the sag but I realized that that rail flexed too much and caused me sag as the other rail extended. I found a stout piece of steel 2.5 inches wide by 2 inches thick. I'm going to weld the v rails and rack gear to this steel as soon as I finish prepping the new legs.
Re: New person
Thanks for the update! Send us some pictures so we can see what you are working with.Batchain puller wrote: ↑Tue Apr 12, 2022 10:28 pm Build update. The bottom rail developed a sag. I made an adjustable support and that helped the sag but I realized that that rail flexed too much and caused me sag as the other rail extended. I found a stout piece of steel 2.5 inches wide by 2 inches thick. I'm going to weld the v rails and rack gear to this steel as soon as I finish prepping the new legs.
- Joe Jones
Re: New person
What is the pitch of your gear rack? You say the gear rotates at "One Turn Per Inch." How many teeth on the small motor belt cog, and on the larger aluminum belt wheel? What is the ration? 1: 4? 1:5? Then it turns the metal gear that looks like it has 24 teeth. How are you getting only one inch of lateral movement out of that gear per rotation?acourtjester wrote: ↑Wed Jan 19, 2022 10:27 am Here is my "Y" drive assembly Small motor pulley, larger on the auxiliary shaft to drive gear. basically motor turns 3 times to shaft 1 turn.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Re: New person
Tom - that is a nice clean setup! Great work. And a great explanation as well.acourtjester wrote: ↑Wed Jan 19, 2022 10:27 am Here is my "Y" drive assembly Small motor pulley, larger on the auxiliary shaft to drive gear. basically motor turns 3 times to shaft 1 turn.
Re: New person
The rack is a 20 tooth per inch and the spur gear has 20 teeth, I will get the sprockets teeth info in the morning
- Joe Jones
Re: New person
That would put the pitch at .050" or 1.27mm. The gear is evidently a lot smaller than it looks in the photo.acourtjester wrote: ↑Wed Apr 13, 2022 10:26 pm The rack is a 20 tooth per inch and the spur gear has 20 teeth, I will get the sprockets teeth info in the morning
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
