TIG torch boom for welding cart
All topics related to mig welding, tig welding, spot welders, flame cutting, etc.
TJS
Post by TJS » Fri Apr 03, 2015 7:53 am
Needed to be able to get my tig cables off the ground and be able to swing it where I need it. Made this boom up.
Used some delrin for the washer/bushing. Maybe I will paint my cart this time, however I usually never paint my stuff cause I am always modifying it anyway.
TJS
Re: TIG torch boom for welding cart
Post by TJS » Fri Apr 03, 2015 8:01 am
SeanP
Post by SeanP » Fri Apr 03, 2015 11:04 am
Good idea there, I'm the same with cables trailing on the floor right across my entrance door as well, might just look into that.
Thanks for posting,,,good job!
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Gamelord
Post by Gamelord » Fri Apr 03, 2015 10:28 pm
Pretty awesome setup! I need to make me one of these for sure. I assume your boom is mounted on your tig cart? Mine would need to be as I move it around the shop from time to time. Is there any issues with the weight trying to tip the cart?
TJS
Post by TJS » Fri Apr 03, 2015 10:43 pm
Gamelord wrote:Pretty awesome setup! I need to make me one of these for sure. I assume your boom is mounted on your tig cart? Mine would need to be as I move it around the shop from time to time. Is there any issues with the weight trying to tip the cart?
Yes welded to the tig cart. Third video shows this. No issues. I have a tig cooler mounted low and a Dynasty 300DX machine so it is heavy enough.
T.J.
Return to “Mig Welders, Tig Welders, Spot Welders”
