Steel Plate Lifting Clamps??
All topics related to fab & weld tables, grind stations, material handling & storage, etc.
Thumper
Post by Thumper » Sun Sep 21, 2014 12:55 am
Im looking for a diy design on building a set of lifting clamps for lifting the sheets up onto the table "Or" a reasonably priced set to purchase. Everything Ive found store bought has been stupid expensive :shock:
I Lean
Re: Steel Plate Lifting Clamps??
Post by I Lean » Sun Sep 21, 2014 5:13 am
Vertical or horizontal lift? For vertical lifting, I got one of these, works great for up to 1/2". (that's as thick as I've tried to lift, and pretty much the max that will fit in it) Bought mine from Amazon, looks like they're still the best price now.
http://www.amazon.com/Vestil-EPC-10-Ver ... B0052PKQPW
For horizontal lifting, the clamps I use look like this:
4 of them on chains, with two spreaders to keep them from sliding together. One pair of chains goes on each side of the plate, and it works perfectly.
East German
Post by East German » Sun Sep 21, 2014 12:14 pm
Homemade CNC Plasma-Watertable with Mach 3
Triple Beast + Leadschine Drive
Hypertherm Powermax 85
Machine Torch + PriceCNC THC
Hypertherm Powermax 1100
Machine Torch + Proma THC
Thumper
Post by Thumper » Sun Sep 21, 2014 9:25 pm
East German wrote:Hallo,
see you here:
http://www.plasmaspider.com/viewtopic.p ... amp#p68207
Regards Peter
That's it, thanks you..
Return to “Fab Tables, Grind Stations, Material Storage & Handling”
