Sheet steel storage cart
All topics related to fab & weld tables, grind stations, material handling & storage, etc.
aaron868400
Post by aaron868400 » Thu Oct 01, 2020 12:24 pm
My first project with my table was to build a storage cart. I have a 2 car garage so space is limited. I have been lurking on this forum for a while and have seen some great ideas. I'm not sure which posts I saw them on but big thanks to the person or people who posted.
Everything is 1/8in wall with 1/8in sheet for the floor. I will soon be getting the engine hoist set up for lifting sheets as they are harder to move than I expected.
2016 Star Lab 4x8
CommandCNC/Linux
Hypertherm PowerMax85
Hobart Ironman 230
Re: Sheet steel storage cart
Post by acourtjester » Thu Oct 01, 2020 4:25 pm
You may want to look at this post Mr. Palmer has a few other things shown that will help :Yay :Like
viewtopic.php?f=87&t=12845&p=90055&hili ... ver#p90055
ian.
Post by ian. » Fri Oct 02, 2020 8:53 am
I worked in a shop once upon a time where an employee was killed with a similar cart. A caster failed and the metal fell on him. I'm sure the cart had much more weight on it then you will.
aaron868400
Post by aaron868400 » Fri Oct 02, 2020 9:43 am
acourtjester- I took a look at the post and watched the video. His setup looks pretty slick. I like it. Might have to build one similar. I may have came across a trade for a forklift to make things easier but well see. Thanks for showing that to me!
ian. - I could see how that is possible. Yes, I wont be loading it too heavily and those caster should be many times stronger than I need. I almost made the cart wider in fear of it tipping but it seems very solid and heavier than I thought it would be. Thanks for the heads up tho!
2016 Star Lab 4x8
CommandCNC/Linux
Hobart Ironman 230
Post by adbuch » Tue Nov 03, 2020 7:45 am
I built something similar for my sheet metal. I will post a photo asap.
Thanks for sharing,
:Like :Like :Like :Like :Like
Return to “Fab Tables, Grind Stations, Material Storage & Handling”
Industry Pros use FastCut CNC
