Remote Control for Any Plasma Table
This is the best $20 upgrade I've ever made. Just plug in the USB dongle and it auto installs. I keep it in a zipper bag when using it, about the only clean item near my table. (Power switch is still easy to access when its in the bag)
Found it on Amazon. Been using it for a few months now. (Also works great on my Smart TV) Scroll to bottom for video.
Here is a short video demo. https://youtu.be/fVMtoplbjss
Re: Remote Control for Any Plasma Table
these work as well
https://www.ebay.com/itm/Wireless-Digit ... jKyHUO8kbQ
Does it work with Command CNC on linux system?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
I have same one on my command cnc, works well. Need to figure out more keyboard shortcuts to do things like change from continuous jog to step and a few other things would be nice. I mostly just use mine for finding corner of sheet.
I don't have wifi in my shop, will this still work?
Yes, it has a dongle that plugs directly into your CNC computer USB port.
Thanks a lot for the info, Granite.
I can't make mine work, it does toggle different tabs on the screen but no movement on the table at all?
Does your CNC use a Windows or Linux computer with a standard keyboard? If so, you should be able to perform all functions with your remote keyboard, the same way you are using your primary keyboard. In fact they work simultaneously.
Open Notepad or some other application outside of your CNC controller and type a word to confirm your remote keyboard is functioning. Keep your primary keyboard plugged in. You should be able to use both at the same time. Type a few lines of text then use your arrow keys to navigate your cursor.
This isn't wireless but it works great on a Mach 3 system
https://www.ebay.com/itm/4-Axis-USB-Pen ... 2749.l2648
I can type in numbers and stuff on notepad, but still no movement whatsoever on the table, there's nothing to change on the settings etc?
try clicking on the NumLock key once (on your normal keyboard) then try the keypad
there is a guy who has a video out showing how to synchronize a remote keypad to transfer command keys to the remote.
https://www.youtube.com/watch?v=F1Siihp0nSo&t=890s
Tried it, no succes, I guess I'll find another remote or something, thanks.
Have you tried it on a different computer? Perhaps they shipped you one with some bad keys.
will it work with a torchmate?
This is basically a wireless keyboard. It should work with anything that would interface with a standard keyboard.
https://www.amazon.com/Upgraded-Rii-Wir ... B00Z81U3YY
