Washing soda amount for water table
szextreme
Post by szextreme » Sun Jun 23, 2019 8:42 am
I have a 5x12x4" table approximately 150 gallons of water how many oz./cups/boxes should I be using for my table?
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinery!
steel 35
Re: Washing soda amount
Post by steel 35 » Sun Jun 23, 2019 10:44 am
I figured mine to be 75 Gallons, and start with 1/2 a box.
Make sure you mix it before dumping in the table, I use a 5 gallon bucket. Its really hard to mix the hard stuff later.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Billythegoat
Post by Billythegoat » Sun Jun 23, 2019 11:11 am
I run about the same ratio as steel 35. 40 gallons and 1/4 box.
I stir the water in 5 gallon pail then slowly add soda.
szextreme
Post by szextreme » Sun Jun 23, 2019 11:18 am
Thanks guys! Should be a full box for me then!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
SegoMan DeSigns
Post by SegoMan DeSigns » Tue Jun 25, 2019 1:26 pm
Depending on the PH of your tap water you will need approx 2- 55ox box's (Mix ratio .8 oz per gal x 55 oz = 70-75 gal / box) Get some PH test strips from the local pharmacy or off of fleebay, you want a PH of 10 or higher - I start at 11 (for those who were throwing spitballs and not paying attention in science class just tear off a PH strip dip it in the mixed solution then compare the color to the color chart)
https://www.ebay.com/itm/100-ct-pH-Hydr ... 6da315ff43
motoguy
Re: Washing soda amount for water table
Post by motoguy » Fri Jun 28, 2019 12:24 am
Subbing so I can come back and check it later. I just toss a box into my 6x12 when I notice rust starting to form. lol
Industry Pros use FastCut CNC
