Refrigerator Type Air Dryer & Using Air Hose
tony506
Post by tony506 »
I just got a Harbor Freight refrigeration type compressed air dryer for xmas. I was wondering if it's ok to hook the inlet and outlet pipes using regular type air hose and quick release fittings instead of black iron pipe. I only ask as I am not sure if the dry air comes from the unit hot and if this will affect the air hose so close to the outlet.
Tony
Eastern Canada
Hobby Shop/Business
PlasmaCam DHC2 with Design Edge
Hypertherm Powermax 65
Lincoln Mig
Everlast Tig & Stick
Garysbiz
Re: Refrigerator Type Air Dryer & Using Air Hose
Post by Garysbiz »
I have the small Macair dryer, I used rubber flex hose on both the inlet and outlet sides. I was mainly concerned with vibration issues which I dont think there really are any, it is just a habit from being an electrician and doing that. I don't think there is any real heating issue. I did keep the hose and all fittings the same size as the pipe though so there would be no restrictions. Hope this helps.
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
I can't see the air coming out hot from a refrigerated air dryer. I would have guessed if anything the outlet air should be significantly colder than the air coming in.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
tony506
Post by tony506 »
Thanks a lot guys for the info. It is a great help and I am going to use the flexible hose to connect it up. I have never used or seen one in operation so your comments were a great help.
Tony
Eastern Canada
Hobby Shop/Business
Lincoln Mig
gaetan9
Post by gaetan9 »
From what part of eastern Canada are you from? I'm new on Here from moncton nb
tony506
Post by tony506 »
Sussex NB
Eastern Canada
Hobby Shop/Business
Lincoln Mig
