3 D Printed diamond scribe holder
All topics related to 3d printers and 3d printed plasma table accessories.
Post by acourtjester » Wed Jan 02, 2019 2:50 pm
Here is a video of a 3 D printed holder for a Diamond scribe I made for my table. This plaque is 3" X 5" on Aluminum. :)
https://youtu.be/-C48ROJ-5KQ
Everlast PM 256 tig
Re: 3 D Printed diamond scribe holder
Post by acourtjester » Wed Jan 02, 2019 4:03 pm
Here is a sample for a serial number plate 2.5" X .960" on cold rolled steel.
Everlast PM 256 tig
Kentuckyfarmer
Post by Kentuckyfarmer » Sun Jan 06, 2019 1:02 pm
That looks really good, may have to get me one of the scribes
Mikw
Post by plasmanewbie » Mon Jan 07, 2019 9:02 am
Very nice! I've got the easysciber diamond scribe and have made some pretty cool things with it. Awesome you 3d printed your own tool holder!!!
Post by acourtjester » Mon Jan 07, 2019 9:29 am
Thanks Just have all the fun I can, buying a 3D printer has helped me learn how to do 3D drawing. :) I have posted other things I have developed and printed for my Plasma/ router table. I will pass along the files if a member would like to make their own or build one for them. :D
Everlast PM 256 tig
SeanP
Post by SeanP » Mon Jan 07, 2019 4:14 pm
That's a grand job there Tom!
Guess hot rolled is a no no for those scribes?
That mill scale is tough stuff!
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Post by acourtjester » Mon Jan 07, 2019 4:22 pm
Thanks I have not tried hot rolled :oops:
Maybe another member that has an easy scribe could reply.
Everlast PM 256 tig
robertspark
Post by robertspark » Mon Jan 07, 2019 6:14 pm
Thanks for the file, I may give it a go cheers
UCCNC,
Hypertherm Powermax 45 (nonXP)
Neuron Lite THC
Hobby user (4x4 home table)
Post by acourtjester » Mon Jan 07, 2019 7:52 pm
PM me with your email address I cannot PM them to you here, these will be the stl files, I have a Tevo Tarantula and the G-codes are configured with a slicer program called ideamaker for that printer. I could also sent the G-code if you want. The short ones are a Drag Knife :lol:
Everlast PM 256 tig
robertspark
Post by robertspark » Tue Jan 08, 2019 11:17 am
Those images are much more helpful.
Thought I'd spotted them here: https://www.thingiverse.com/thing:3340487
UCCNC,
Neuron Lite THC
Post by acourtjester » Tue Jan 08, 2019 2:27 pm
yes that is my posting of the item.
Here are the linear bearing I used you may need another auction to get them in the UK.
https://www.ebay.com/itm/6pcs-LM8UU-8mm ... 1438.l2649
and the chrome shafts again shipper to the UK
https://www.ebay.com/itm/8mm-x-1000mm-L ... 2749.l2649
The screw holes in the mounts are set for 10-32 thread don't know the metric size. I press the bearings in first then slide that rods in and press them in the top then the bottom so the distance between the rods is maintained. I use a vice to do this. Cutting the rods to length I use a cutoff wheel as they are very hard.
Everlast PM 256 tig
robertspark
Post by robertspark » Tue Jan 08, 2019 2:52 pm
Thanks, I've been using these igus ones as they seem to have better support and less play than the bearing ones
https://www.ebay.co.uk/itm/3D-Printer-S ... 1571607189
UCCNC,
Neuron Lite THC
Post by acourtjester » Tue Jan 08, 2019 3:55 pm
You will need 4, 2 on each side
Everlast PM 256 tig
motoguy
Post by motoguy » Tue Jan 08, 2019 8:55 pm
I've had a CR-10 for about a year now. This may need to be it's first project!
Post by acourtjester » Tue Jan 08, 2019 10:32 pm
I have used mine for many projects very handy tool to have :D
Everlast PM 256 tig
East German
Post by East German » Wed Jan 09, 2019 1:37 am
Thanks Tom
Load from Thingi
Peter
Homemade CNC Plasma-Watertable with Mach 3
Triple Beast + Leadschine Drive
Hypertherm Powermax 85
Machine Torch + PriceCNC THC
Hypertherm Powermax 1100
Machine Torch + Proma THC
TPE
Post by TPE » Tue May 07, 2019 12:22 am
Hello,
I am new to the forum and cant see how to PM you yet am interested in the drag knife and scriber assemblies. I just got a 4x8 Wright CNC table and need to get some projects done asap.
thanks!
Josh
Post by acourtjester » Tue May 07, 2019 9:29 am
This is what you need to do to send a PM to a member :Yay
Everlast PM 256 tig
Nacs Fab
Post by Nacs Fab » Mon Jan 06, 2020 10:37 pm
Tom, what diamond scribe are you using? I may have to print some up! Thanks for the Share!!
G540 with LCTHC by candcnc
all built... by me...
Post by acourtjester » Tue Jan 07, 2020 10:48 am
I have use a few different ones it seems the best is the one from "Easy Scribe" they sell a replacement tip. I have also used a diamond tipped used for grinding wheel dressing, they do work and are cheaper but the angle of the tip is not as sharp. I have found others on eBay that could work too. https://www.ebay.com/itm/RDZ-1-8-60-CNC ... 1438.l2649 But these are the same price of the Easy Scribe replacement tip :HaHa
Everlast PM 256 tig
Return to “3D Printed Accessories”
