3D Deer Head, Craigslist find
Has anyone ever seen this? A friend of mine asked me to cut this, I have never seen the dxf anywhere.
- Attachments
- deerhead4.jpg (7.52 KiB) Viewed 18250 times
- deerhead3.jpg (6.55 KiB) Viewed 18250 times
- deer head2.jpg (7.69 KiB) Viewed 18250 times
- parrotlady
Re: 3D Deer Head, Craigslist find
Yes! That is from Cardboardsafari I am pretty sure! They have some amazing 3D things made of cardboard.. I emailed and asked them if there was any way I could buy a file for a one time use, and they pretty much told me exactly where to shove it. They said I could if I was a billionaire. Nice.
Good luck with that
April
Good luck with that
April
i hate when people act like that. its not like they made something on their own.they dont want to share what they copied what A**holes. now you can make one and send them a pic to shove it
- Attachments
- Deer Head[1].zip
- (196.93 KiB) Downloaded 2039 times
- parrotlady
Nice! Thank you! I agree, there is no need to be an a$$... a simple "no" works just fine
Here is a cleaned up dxf if it helps anyone. I feel like part of an underground revolution now.
- Attachments
- 3D deerhead.dxf
- (210.61 KiB) Downloaded 2815 times
- parrotlady
Nice!!! Now if anyone has the elephant head, I would be forever in their debt!
April
April
I like the 3 D deer head but when I open it in corel draw x4 the lines are broke apart
This is my first post on here and would like to say thanks for a great file.
Can you please tell me what thickness of steel this is cut from as my cad program shows .220 " for the slot width, is this correct?
Andy.
Andy.
Nice Thankyou for sharing. Man there's soooo many cool things on this site.
Thanks for the post! I cut this file out of an old metal shelf. It was 18ga with grey paint.
question for you Shelby
Did you resize the slots for the 18 gauge or just deal with the slop?
thanks
thanks
Randy Dobbins
Welding Teacher Humble ISD
I just held the the pieces to one side of the slot, making sure to pick the same side every time.
I started with the "wall base", flat on the table. Then putting the "long pieces" in the "wall base", holding them vertical with magnets. Weld the nose on, toward the front of the slot. This will hold every thing up and kinda square. I started at the back, and worked toward the front.
I hope this helps.
I hope this helps.
I made a similar cutout from 11 gauge. Its pretty heavy but still a nice addition to the garage.
thanks for posting this. i trying to figure out something before i try and cut it. there seems to be more pieces than there is slots. i understand the horns the 2 parts with the slots in the center of them but there are 14 others parts and only 13 slots. i missing something but cant figure it out. any and all help would be greatly appreciated.mrush wrote:Here is a cleaned up dxf if it helps anyone. I feel like part of an underground revolution now.
That turned out cool.
I cut one of these yesterday. I didn't have time to look it over before I put it int he acid bath. I need to go tomorrow and get it out to see what It's going to look like. I resized the slots to fit the stock on hand 16 ga.
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Hypertherm Powermax 45
Auburn, AL
www.facebook.com/decorativemetalworks
Auburn, AL
this one is 3/16". hung it on the front of my house
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
- Buzzard Gut
That actually looks pretty darn Cool! And I think it looks a lot better than the top pictures!
The older I get, The better it was!
way cool. ive seen alot of 3d puzzles out there. next to the 10' tall t-rex, this one is the coolest.
only one time have i seen a moose, but it was cardboard and just a photo. any info on one a those would be appriciated.
viva la revolution!!!!
We made this one in our Metal shop at school. It is 3/16" and weighs about 70lbs! Had to get the lead shields and lag screws out to hold it to the wall. We used Muratic Acid followed by vinegar to rust it and then shot it with some clear coat.
I decided to give it a try, the kids and I put it together. We made a stand for it and I put it in an auction for scholarships this weekend. It brought $600 in the auction--pretty pleased!
Randy Dobbins
One of my first projects on our new table. I decided to cut my father in law a gift and this is what I came up with. Thanks for the file share, it was fun!!
Here's mine, thanks for sharing. I scaled it to 14 ga material. I noticed one piece scaled slightly smaller and one antler did not cut correctly. It was not mirrored so, have to correct that on the next one. Now to cut one out of 10 ga. Should be interesting.
On a side note finally got my ohmic sensor made correctly, so I have proper contact. I only had one metal strip previously, that sucked, now, much better. This cut out with minimal and I mean minimal amounts of dross.
Will you be willing to share your DXF file for cutting this from 16g?dustywill wrote:I cut one of these yesterday. I didn't have time to look it over before I put it int he acid bath. I need to go tomorrow and get it out to see what It's going to look like. I resized the slots to fit the stock on hand 16 ga.
Thank You
Here it is. It is a little too tight on my machine. You can do one of two thing. Scale it up slightly or change the kerf on your tool in sheetcam to be slightly smaller than it really is. I would scale it personally.LCPL Kemp wrote: Will you be willing to share your DXF file for cutting this from 16g?
Thank You
I hope this helps,
Byron
- Attachments
- 3D Deer Head.dxf
- for 16 ga steel
- (253.17 KiB) Downloaded 784 times
Auburn, AL
Auburn, AL
