Creating a vintage sign
- Scratch
I wanted to create a vintage looking sign for my pole barn. I collect old Jeeps so I found some google images of what I was thinking and customized it to my liking. There's not much CNC plasma cutting, but I thought some of you might like to see my process, maybe it'll spark some idea for someone.
Now, I'm no artist by any means, but I do have a vinyl cutter so I thought I could create a stencil, then use spray paint for the color, and finally distress it to my liking.
I think I'm going to make my sign about 30" high and about 25" wide and will probably make it out of 16 gauge steel, but before I cut out the shape of the sign, I wanted to make sure that my plan would work. I've had issues with using vinyl as stencils before and I've never distressed a sign either so I wanted to do a test run on a much smaller scale.
I found a piece of scrap steel I had. This one is 1/8" thick and about 11" square.
I cleaned it up with a wire wheel grinder then sprayed a coat of primer first, then flat white on top of that.
I wasn't exactly sure of what I wanted the dealer info to say, so I drew up a few different designs.
I picked one, then I cut out the vinyl and weeded it. I used orange vinyl because "orange man bad" right?
Next, I applied the transfer paper. This is only to help apply it and gets thrown away like all my hopes and dreams.
I peeled off the transfer paper and used Rustoleum 2X satin spray paint for the red, blue and black. In this picture, the paints are all dry but you can see all those black specs in the white are where the vinyl peeled up some of the white exposing the steel below. I waited almost 24 hours to apply the vinyl over the white, but it's possible I didn't wait long enough. I also didn't wait long enough to start peeling off the vinyl on the blue paint at the bottom. According to my wife, I have a problem with finishing things too soon...
Finally I used a green scotchbrite pad to remove some of the gloss and distress the paint.
- Scratch
Re: Creating a vintage sign
I think it turned out awesome and feel good about making another in full size. I'm even liking the peeled up dots all over the place, so I found a sheet of 16 gauge about that size.
Then I tossed the sheet on my plasma table and cut out the shape
I cleaned up both sides. It ended up being about 32" wide X 28" tall.
Then did the same process that i did on the smaller one. Here's a pic of it after all the painting is done and the vinyl peeled off. I guess waiting a little dry more time helped since the white didn't come up this time. It looked so good, I had a hard time deciding if I should distress it or not.
And here it is after all the distressing is done. I'm debating about putting a couple bullet holes in it, and possibly adding some rusted edges... not sure yet. When I decide where it's going, I'll figure out mounting holes.
And some detail pics, I love the way it turned out, especially the black letters!
- Joe Jones
If you want to have some fun, mount a PAINT PEN to the Z on your CNC table, and draw the files. Have the CNC table lower the paint pen to the surface and PAINT the sign for you.Scratch wrote: ↑Mon Mar 07, 2022 9:50 pm I wanted to create a vintage looking sign for my pole barn. I collect old Jeeps so I found some google images of what I was thinking and customized it to my liking. There's not much CNC plasma cutting, but I thought some of you might like to see my process, maybe it'll spark some idea for someone.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Thanks so much for sharing your process with us! I don't have a vinyl printer, but I do have a Cricut machine that I haven't used yet - but I think can do the same thing on a smaller scale. I like the way you used the different colors of spray paint in conjunction to your mask to create your sign.Scratch wrote: ↑Mon Mar 07, 2022 9:50 pm I wanted to create a vintage looking sign for my pole barn. I collect old Jeeps so I found some google images of what I was thinking and customized it to my liking. There's not much CNC plasma cutting, but I thought some of you might like to see my process, maybe it'll spark some idea for someone.
Great Work!!
- Joe Jones
Story of my life. I have about a dozen machines in my shops that I haven't used yet.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
- Scratch
Yeah, My vinyl cutter is basically a big Cricut machine that accepts rolls of vinyl. A Cricut machine would work great on a smaller sign.
If anyone is interested, I have a USCutter brand 28" SC2 machine.
Thanks for sharing that. I will have to take a look to see if that is something for me to get.
Ah yes expanding the use of your CNC machines/tables for fun Joe sounds like you in the Dungeon doing you painting
Scratch you going to have Mike Wolfe from Antique Archaeology knocking on you door wanting to buy the (great looking) old Jeep sign
I'm to cheap to buy a Cricut machine so I printed out a drag knife holder for my CNC table to add to the fun in the shop. You can also acid etch aluminum with sign vinyl stencils.
- Scratch
Funny, your posts about your drag knife is the reason I started researching vinyl cutting. I decided against adding one to my table since at the time, my slats looked like this and I was too lazy to change them.acourtjester wrote: ↑Tue Mar 08, 2022 9:08 am Ah yes expanding the use of your CNC machines/tables for fun Joe sounds like you in the Dungeon doing you painting
- tinspark
Those signs look great!!
I just chipped my cutting grates off yesterday but weren't near that bad.
I Was cutting square holes in flat bar for fence pickets to pass through, and the bar wasn't laying as flat as I liked.
THC would wiggle the bar and move it a bit each time.
I think you might get more blowback with all of that slag and possibly lessening consumable life.
Also, when I cut over a slat or slag, there is always excess slag under my work piece which makes it harder for me to clean my parts.
Love the signage. Looks great!!
But the slats made my day!! knarley dude!!! hahah
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
- Scratch
Some people collect Pez dispensers. I was collecting slag.
Those things weighed a ton when I changed them!
- tinspark
you might have a gold mine there when U send em to the scrap yard!!
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
