Interior Farmhouse sign, two layers
- gblaylo
Had a request to build this which is going to hang on the wall in someone's farmhouse. Was told it is going to be a birthday present, size is 35" X 22". Powdered coated Stone Black and RAL Cream.
- ROKCRLER
Re: Interior Farmhouse sign, two layers
Very nice! How did you attach the two layers?
- gblaylo
If you look closely you can see three holes in the top and three in the bottom. Screws will pass through both layers into the wall. The wall on which the sign will be mounted on is wooden planks so it will be plenty strong. I also powder coated the screw heads so they will be almost invisible.
gblaylo wrote: ↑Tue Mar 01, 2022 9:28 pmIf you look closely you can see three holes in the top and three in the bottom. Screws will pass through both layers into the wall. The wall on which the sign will be mounted on is wooden planks so it will be plenty strong. I also powder coated the screw heads so they will be almost invisible.
Very nice with the details you have in the plaque, 5 fonts gives it more character and the size allows for more of the smaller details to show.
