Trestle Table
bhamer62
Trestle Table
Post by bhamer62 »
Seen one of these on here some years ago, finally had the opportunity to make one for the conference room at work.
3/8" plate for most parts
3x5x5/16w tubing
1" plate for arched trestle
Hammered rivets from King Architectural
2" thick Cherry wood
Heat and oil rub finish
Re: Trestle Table
Very nice! Thanks for posting a picture.
ROKCRLER
Re: Trestle Table
Post by ROKCRLER »
Pretty sweet!
4x8 Dynatorch
PM85
~Mo~
Re: Trestle Table
Hats off to the industrial style, very nice :Like :Like
Re: Trestle Table
Great work!! I like it.
greggomc
Re: Trestle Table
Post by greggomc »
I like it also. Very nice job.
Happy New Year.
Gregg
tinspark
Re: Trestle Table
Post by tinspark »
Nice work. Love the rivets . Cool touch!
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
DieselFumes
Re: Trestle Table
Post by DieselFumes »
WOW, that is amazing! Very nice job. How did you get that uniform color and finish on the steel plate and rivets?
Re: Trestle Table
If you made the top larger and added shallow draws to the back it would make a great desk. :Yay :Like
bhamer62
Re: Trestle Table
Post by bhamer62 »
Thanks all
Diesel, for the oil rubbed finish, you simply take a MAPP or Propane gas hand held torch and heat stuff up till it's just a lil too warm to hold on to, then use a crappy old paint brush and apply Bri Wax, https://briwax.com I like Tudor Brown. It liquifies, slather it on and let it go, all done....
acourtjester, It would indeed.... Planning on modifying the design a bit for coffee table legs and also sizing it up a bit for a live edge dining table. Now that I got to make one and see it, I can adjust things a bit for other uses.
Re: Trestle Table
Ok now you will need to post pictures of those when you are done, I'm sure there will be some here waiting to see them.
Hey a steampunk lamp and you off to the races. :Like :Like :HaHa
East German
Re: Trestle Table
Post by East German »
Great work!
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
SegoMan DeSigns
Re: Trestle Table
Post by SegoMan DeSigns »
Looking good :Like :Like
Is that the Yoder of Yoder Machinery?
bhamer62
Re: Trestle Table
Post by bhamer62 »
Sego, no but they are from Ohio, it may be a relative...??? At our shop we have 8 Lasers with 5x10 with pallet changers, the newest one is a 12K fiber, 4 CNC brakes, 2 water jets, a tube laser, do some rolling and just got a new fiber laser welder..... I'm just a Project Manager that likes to play on the side and do my own thing. I'm just a squirrel trying to get a nut.....lol
jester, gettin ready to start making some table legs designs, lots of people doing wood working these days with live edge and the only thing they can find is those hairpin legs and square tubular stuff......I'm thinking if I buy a $1200 slab a wood I would want some sexy legs under it...hoping to create an opportunity....
tinspark
Re: Trestle Table
Post by tinspark »
bhamer62 wrote: Wed Jan 05, 2022 3:19 pm For the oil rubbed finish, you simply take a MAPP or Propane gas hand held torch and heat stuff up till it's just a lil too warm to hold on to, then use a crappy old paint brush and apply Bri Wax, https://briwax.com I like Tudor Brown. It liquifies, slather it on and let it go, all done....
Some guys use the same process for larger items like smokers. They use a 5 gallon propane tank and a weed burner to heat up larger areas of metal and then rub boiled linseed oil on the surface to inhibit rust and add a nice finish. That stuff is pretty cheap too.. I get it at the "Homie Store" and keep a little on hand cause it also restores wood knife handles (no heat needed here) after the kids habitually dry them out in the dishwasher..
https://www.homedepot.com/s/boiled%2520 ... oil?NCNI-5
Doug,
Hypertherm 45XP-
BAR M
Re: Trestle Table
Post by BAR M »
Very nice. Good design.
Re: Trestle Table
SegoMan DeSigns wrote: Thu Jan 06, 2022 12:05 pm Looking good :Like :Like
Not to be confused with Yoder power hammers.
DieselFumes
Re: Trestle Table
bhamer62 wrote: Wed Jan 05, 2022 3:19 pm Thanks all
Awesome thanks for the info, I would have never stumbled onto that technique. Sounds nice and simple for such a cool appearance. One of the nicest project picture posts I have seen in a while :Like :Like
SegoMan DeSigns
Re: Trestle Table
Thanks for the update on the names and finish information.
bhamer62
Re: Trestle Table
Post by bhamer62 »
Thanks for the kind words, the Bri Wax technique doesn't like smooth or oily material as well as it likes rougher stuff, the nastier the material the better it works. I have used it alot on hand railings made from hammered pipe or forged stuff. No cleaning required.......
One important side note, do not hit the Bri wax can with a flame!!! Extremely flammable when it's wet!!!!! Your work will catch fire occasionally, just blow it out.......if you let the area dry you are working on before heating near it it usually won't lite up, only have to wait about 30 seconds. It is not as dangerous as it may sound if you are careful.....I still have all my eyebrows.....lol We have done hundreds of lineal feet of hand railing like this....
Re: Trestle Table
Very nice edge quality. Was this cut with laser, hi-def plasma, or regular plasma?
bhamer62
Re: Trestle Table
Post by bhamer62 »
Cut on our new 12K Fiber optic laser....Thing is amazing... I can cut a .100 dia hole thru 1" plate with a clean dropout.....and yes, 0.100 was not a typo!!! The pierce on that is only .006
Re: Trestle Table
That 12k fiber laser gives super clean cuts - as it should considering it is a "top of the line" machine. Thanks for sharing the information.
weldguy
Re: Trestle Table
Post by weldguy »
bhamer62 wrote: Tue Jan 11, 2022 9:39 pm Cut on our new 12K Fiber optic laser....Thing is amazing... I can cut a .100 dia hole thru 1" plate with a clean dropout.....and yes, 0.100 was not a typo!!! The pierce on that is only .006
Um....wow!
4Dscreenart
Re: Trestle Table
Post by 4Dscreenart »
Looks Great! 3/8 plate I bet that table is very haevy
