Just finished this project for our gate. The gate was already there. I cut the steel, welded the ring, cut the gate, and welded in the insert.
The insert is 40" tall x 79" wide.
What would a person charge a customer for something like this?
Thanks for your input,
Scott...
Entry Gate
Re: Entry Gate
Scott - I would say $500-600 minimum. How many hours do you have in it, and what was your materials cost?
- tnbndr
Re: Entry Gate
With remote welding, painting etc. I would be at around $1200 + for this.
Nice job.
Nice job.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Entry Gate
I have $100 in materials. About 4 hours from material store to finished product. About 2.5 hours to.cut gate, grind and weld in place.
Thank you!
Scott...
Thank you!
Scott...
Re: Entry Gate
Nice
- levesquea
Re: Entry Gate
I would charge $1,000 to $1,200
Plasmacam 4x4
Hypertherm Powermax 45
Everlast power Tig 255
Affinity Designer
Alibre expert
Vectric Aspire 10
Affinity Designer
Alibre expert
Vectric Aspire 10
Re: Entry Gate
OK - I just realized that you did the insert, and didn't build the entire gate. In that case, I would agree that $700 to $1000 would be a reasonable estimate.
