I tried my hand at the file I found here for the six sided pit. I changed a couple of things, but I think it turned out excellent. Cut from 3/16” HR.
Just an FYI, the bend angle between the legs and upper panel is 56°.
Six sided fire pit plasma cut from 3/16"
Re: Six sided fire pit
Love it!! Nice job
Turned out really nice.
What part of AK are you in? I'm in the Fairbanks area.
What paint did you use on it?
I was in the Mat-Su for 46 years, we moved to NW Arkansas in 2018.NorthernFX wrote: ↑Wed Apr 22, 2020 11:53 am Turned out really nice.
Normally I use Rustoleum high heat, but I can't find it in quart cans now that I have a spray gun so I have been using Krylon high heat from Lowes.
can you share the file for the 6 sided fire pit
- tnbndr
Re: Six sided fire pit plasma cut from 3/16"
Nice work.
For others that don't have a brake, you can cut the sides and base as separate items and weld them together. Just a little more welding.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Is this file available on here? Cant seem to find it.
