My new 2X72 Steampunk Belt Grinder
- Scratch
I've been wanting a 2X72 belt grinder for a while now, and after getting a free working treadmill that I had no need for about a year ago, ( I've made it a personal motto of mine to only run when being chased by zombies) I decided to build one. I really liked the idea of Jeremy Schmidt's grinder with the tiltable belt, but wasn't sure I really needed that. Plus I didn't have a lot of 3/8" steel left over and didn't want to buy more. I liked the simple design of DCKnives grinder and had all the steel so I decided to go with that one.
I bought a set of wheels on eBay right away so I would be committed, then got some belts and after taking way too long, I started to build. Sorry for the "No Progress Pics" thing as once I got started, I kind of got into a groove and forgot to take pics.
Normally, when I build a tool, I paint them all the same color. Machinery gray. And this one was going to be the same. I might throw in some black too just to be crazy. I really liked the simple look of this one and planned on it looking pretty much just like this when complete.
But that tilting belt thing from Jeremy Schmidt's design kept bugging me, so I thought that if I thought I could somehow incorporate that into my grinder, I would at least TRY to do it. It turns out I could, and it works pretty well too!
One thing I didn't like about the DCKnives grinder design was to change the belt, you have push down on the top of the Pillar with your hand, to loosen the belt and remove it. In Dan's design, he attached an 8-Ball to the top to make it more comfortable to push on. I've seen others using a golf ball, a novelty skull, a baseball etc... but I didn't really like that idea that much. I've seen other designs with a lever to pull down and I thought I'd try to incorporate that into the design, so I drew up this lever and mount, (highlighted in yellow) then cut it out on my CNC table.
The lever worked awsome! I even had a 2" stainless steel ball bearing laying around so I used that as the tip. It LOOKED really good too...
A little TOO good I thought to myself. Too good to be on this boring, simple, gray grinder that I was building......
At this point in the build I found myself using the lever to compress the pillar all the time because it worked so well and looked so nice. During this time I kept thinking the lever and mount reminded me of something......
STEAMPUNK!
It was then that I decided to make the worlds first "Steampunk Belt Grinder." (I couldn't find one on the Google so I'm making that claim right now damnit!) I'm not really into steampunk, but I do appreciate the look, and I've always wanted to make something functional in the steampunk theme. Now I guess I have a piece of functional art!
Again, no progress pics were taken but here are some pics of the finished build.
Enjoy!
When tipping it on it's side, I can use the same work rest by sliding it out and turning it a quarter turn.
STEAMPUNK!
Enjoy!
- Scratch
Re: My new 2X72 belt grinder
I incorporated a working Voltmeter into it too.
Steampunk has gears right? Good lord I hope so! I used enough of them!
Added a little personal touch to the back with a nod to who I got the plans from (Dan from DCKnives calls his the BG-272. This is the BG-272SP!)
Holy Gear Train Scratch that neat, is there a place to buy the steampunk gears or did you cut them.
Looks much better than Battleship Gray (sorry old Navy guy )
You get to keep the oldest 10 year old title
- ben de lappe
That's awesome Scratch. Sooo much better than battleship gray. (aircraft gray too! )
Any plans on steampunking the plasma table?
- steel 35
Very nice, especially the right hand pull!
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- WyoGreen
Ahh man, just when I thought I had figured out the design of a 2 x 72 belt grinder, you go and blow up my mind with possibilities!
Dang it all, back to the drawing board!
Thanks for the inspiration, Steve
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- Larry83301
Very nice belt sander, hadn't thought of steampunk design. Looks great!
- Scratch
Thanks all, I'm sure there is a place to buy gears for steampunk decor, but I just cut them out. I know a guy with a CNC plasma cutting table.acourtjester wrote: ↑Sat Nov 16, 2019 9:59 am Holy Gear Train Scratch that neat, is there a place to buy the steampunk gears or did you cut them.
Great use of the small scrapes
where did you get the big spring inside for tension.
i see you even used some of the faux rivets
- Scratch
The spring came from my mystery bucket of random springs that I've been collecting for 20 years. We all have one of those buckets don't we? It's rusty, about 3" long, an inch wide, and worked perfect. No idea what it's from.acourtjester wrote: ↑Sat Nov 16, 2019 7:46 pm Great use of the small scrapes
Thanks yes sir spring box in my shop too.
- tinspark
Re: My new 2X72 Steampunk Belt Grinder
Awesome. That's one of the coolest things that I've seen built in a while.
Love the "working voltmeter"too!
Regards,
Regards,
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Absolutely one of the COOLEST looking projects posted on here in a while. Scratch your projects have blown my mind for years! Thanks for posting another one. So awesome!
- Scratch
Thanks all, it was fun to build.
Excellent!
Dave Hanks
Dave Hanks
This is awesome! Blows my mind what people can come up with! I've been planning on building another belt grinder, this definitely changes some things!
That looks great.
Thanks for sharing.
Jim
Thanks for sharing.
Jim
Combining art with functionality, I think you're on to something BIG!
That is truly amazing!
Awesome build man!
Awesomeness!
- levesquea
Amazing job. The perfect Belt Grinder with an amazing LOOK.
Plasmacam 4x4
Hypertherm Powermax 45
Everlast power Tig 255
Affinity Designer
Alibre expert
Vectric Aspire 10
Affinity Designer
Alibre expert
Vectric Aspire 10
- ETCWeld
Very Nice!
