Anyone have dxf files for these they would share?
http://somentecoisaslegais.com.br/arte/ ... om-o-vento
Dave Hanks
Amazing wind Art
Re: Amazing wind Art
After looking at the top one you can see each of the moving parts are a series of cupped discs pairs. There are 2 large discs mounted near the center pivot point shown in red
then the next size smaller following this pattern out to the tip. Each "S" section is mounted on a tubular circle which passes through the center pivot point of each section. Each is linked to the next section so as they rotate about the tubular circle together in a inside out pattern.
- Attachments
- windmill.JPG (18.81 KiB) Viewed 1391 times
Anthony Howe is a member here, p.m. him .
His wind art is amazing, check out his website.
If I could afford one I would just sit in my yard and watch it all day.
