Finished up a furniture store project today. I made and installed the pole sign and the facade. The pole sign is 25' tall, the circle is 10' diameter. The black is the back layer then the white stands 3" in front of that with the 'O' and couch cushion spaced 1.5" in front of that. White lights between the white and black layer and red lights behind the red layer. No pics of it lit yet but the facade is amazing at night!
Furniture Sign Project
- rdj357
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- WyoGreen
Re: Furniture Sign Project
Very nice. Looks like quite a bit of work went into it. The night time picture is quite nice, congrat's on a job well done.
Router
Laser
Router
Laser
- little blue choo
Nice job Robert.
Rick
Rick
Rick
Arclight 9600 4x8 table
Very impressive. Well done.
- dgeorgester
this looks great
- rdj357
Thank you all, it was a fun project. I lit it up and am going to add some more white lights. It would look great except it's not nearly as bright as the facade and next to it, looks a little dim - good thing I used a large enough transformer to load it up with some more lights!
Robert Johnson
- tnbndr
Nice job! I actually think the facade is too bright, looks washed out. I think they should change theirs!!It would look great except it's not nearly as bright as the facade and next to it, looks a little dim
- rdj357
I did that too That pic is one that someone took and posted to Facebook so it's not great quality. I have a better one I'll post that is a better representation of what it looks like. It's killer at night. I want the pole sign to match.tnbndr wrote:Nice job! I actually think the facade is too bright, looks washed out. I think they should change theirs!!It would look great except it's not nearly as bright as the facade and next to it, looks a little dim
Robert Johnson
