Everlast Plasma problem
Discussion forum for Everlast & Longevity plasma cutters
KoenigCNC
Post by KoenigCNC » Wed Jun 26, 2019 3:42 pm
I have a Everlast 80 Amp plasma that I have fitted to a cnc table. The pilot are is not working when I trigger the torch I hear the relay kick in but no spark. When I stop the torch I get the post flow air then it shuts off new consumables, Swirl ring shield and electroid. No Blown fuses I am running it with a 80 Amp machine torch with good clean air pressure. I can scratch start the torch then quickly jog it up and cut by jogging the torch around the part.
Took it apart nothing apparently disconnected or burnt inside the case. Shipping back to everlast is a long painful expensive process and the machine is not worth it. It has been repaired by them before when it failed within 10 days of getting it and it has never run well. It part of a machine that is being donated to a program that helps at risk teens develop job skills. The CNC Table is working well but the Everlast has failed. Anyone with any possible ideas to fix it please respond
yseguy
Re: Everlast Plasma problem
Post by yseguy » Sat Sep 28, 2019 11:02 pm
I know you probably figured it out by now but just in case someone else is having this issue heres what caused it on my 60s. To start the arc the electrode needs to be able to slide freely 8n the torch body. The lower part of the machine torch that houses this slide mechanism is made of plastic and if your torch holder clamps it too tightly it will not allow it to slide and youll get the relay click, the air flow but no arc. Try loosening or moving the position of the clamp and make sure the electrode slides with little to no resistance
Adam Seidon
Post by Adam Seidon » Sun Sep 29, 2019 7:09 pm
Hi My name is Adam. I have an Everlast 60 also, I never thought of that. I will check it out. I have another problem, I am having with trouble hooking up the auto metal sensing. So the torch will raise automatically when the metal starts to warp from cutting. I tried to talk to Plasma Cam techs but they are no help. and Everlast tech have not had enough experience with Plasma Cam. I can be contacted by phone 941-350-8996 or email adam@ahfab1.com
Thank You
Adam Seidon
A H Fabrications
Rodw
Post by Rodw » Mon Sep 30, 2019 6:32 am
Adam, I had a 50s, that is not an Everlast problem. Unfortunately, I'm like your Everlast Tech. I have no experience with Plasmacam!
Everlast have their faults but their voltages do not behave any different really to my Thermal Dynamics A120 (other than my 50s was single phase and the voltage was a bit noiser, but not enough that it could not track torch voltages).
phy6
Post by phy6 » Fri Jan 03, 2020 6:03 pm
I had a similar experience on my IPT-80 torch on my PowerPlasma 80S last night. I had replaced the consumable electrode and nozzle, and I think I either didn't wipe down the inside of the nozzle/electrode or I screwed it on too tight. The plasma arch was igniting inside the nozzle and not coming out, I could tell by the fresh black marks on the inside of the nozzle when I took it apart. Cleaned it out with acetone and a rag, and used a scotchbright to get the electrode body looking shiny again. Wiped with acetone again and cleaned it carefully. Worked like a charm after that.
Lesson for me: Keep the electrode and inside of the nozzle clean from hand oils, and don't screw it on too tightly.
chavadj
Post by chavadj » Thu Oct 15, 2020 12:51 pm
Does anybody has a wiring diagram or pictures of the ipt80 torch. Mine just burned and i am fixing it . Im using it with everlast 60s. Thanks in advance.
My email is sallongdj@gmail.com
Return to “Everlast & Longevity Plasma Cutters”
Industry Pros use FastCut CNC
