Everlast Plasma problem
Discussion forum for Everlast & Longevity plasma cutters
KoenigCNC
Post by KoenigCNC » Wed Jun 26, 2019 3:42 pm
I have a Everlast 80 Amp plasma that I have fitted to a cnc table. The pilot are is not working when I trigger the torch I hear the relay kick in but no spark. When I stop the torch I get the post flow air then it shuts off new consumables, Swirl ring shield and electroid. No Blown fuses I am running it with a 80 Amp machine torch with good clean air pressure. I can scratch start the torch then quickly jog it up and cut by jogging the torch around the part.
Took it apart nothing apparently disconnected or burnt inside the case. Shipping back to everlast is a long painful expensive process and the machine is not worth it. It has been repaired by them before when it failed within 10 days of getting it and it has never run well. It part of a machine that is being donated to a program that helps at risk teens develop job skills. The CNC Table is working well but the Everlast has failed. Anyone with any possible ideas to fix it please respond
Return to “Everlast & Longevity Plasma Cutters”
