thoughts on my new LDR table
Bought a new 4x4 table from Dan at LDR, have had it for about a month now and slowly getting the hang of it,
few things , first the quality. absolutely top notch, I looked around for quite a bit before i decided on LDR, I would recommend to anyone, very solid and well built .
second , the support. Dan knows these machines inside and out. period. he has had the answer to every stupid question and situation I've gotten myself into. --also very patient and responsive.....
Looking forward to many years of cutting
thanks Dan.
thanks Dan.
- Elite Contributing Member
Re: thoughts on my new LDR table
Dan is an awesome Guy! Great to work with.
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
- ColoradoWayne
I've had my LDR table for over 5 years with the same experience. Still running strong!
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
- tnbndr
I have had my LDR 4x8 for over 6 years with nothing but minor, mostly operator errors. I just had an issue with the gantry twisting, sent Dan an email with a video. Within an hour he emailed me his suggestion for a solution, and of course it worked. Simple problem that I had not thought of. Loose connectors at the control board!!!
PM45
Miller 215
RW 390E Slip Roll
PM45
Miller 215
RW 390E Slip Roll
I've talked to Dan when I was getting ready to get a new table. I ended up going with what I knew.
I talked to him several times and he gave me a good feeling that if I got a table from him that he would be there for me. If I end up looking for another table I'll certainly be talking to him.
6’x12’ Dynatorch with a powermax 85
10’ Wysong brake
5’x5/16’ wysong rolls
3.8’x10’ Pearson shear
65 TonEdwards ironworks
Misc welding machines
Lathes mills
10’ Wysong brake
Lathes mills
Thank god, I thought I was the only one with dumb questions for Dan...lol
