watched this today and thought a DIY type may like this. It is a simple tubing notcher from another DIY guy on YouTube.
simple tubing cutter
Re: simple tubing cutter
Thanks, watching it now.
I have been watching his videos, except for the cross cart stuffacourtjester wrote: ↑Thu Feb 09, 2023 12:18 pm watched this today and thought a DIY type may like this. It is a simple tubing notcher from another DIY guy on YouTube.
Nice video! I had to check out his home page just to find out what a crosskart is. Now I know.
- Scratch
I really like that idea. Let’s say I were to build something similar, then disconnect my x servo and plug in this one in it’s place.
How would I figure out the math for the cut without using G code, but using a drawing program instead?
Like if I have a 2” tube and I want to cut a standard notch for a 90 degree joint in another 2” tube. I get that the cut, if laid out flat, would be kind of a smooth V or sine wave shape. Shouldn’t I be able to just draw that shape with like a 1/2” height and 5” width? Any ideas on how I would go about drawing that shape without just doing trial and error?
For a 90 degree I would draw a circle and break it in half then flip one of the halves around and join them to form like a double hump. Circle would be the diameter of the tube.
- Scratch
Wow, I guess it really could be just that easy. For some reason I thought it would be something more like this, but now that you mention it... it's probably that simple.
I'm going to have to look into that I think...
