So now that I'm laid off of dirt work until spring as the band Styx said it best "Too much time on my hands"!
Got kind of sick of worrying so much about tip ups so I decided to add some extra slats to my table where I do the most cutting. I got a bunch of 1/4" x 1 1/4" x 44" long flat bar from work for free. Kinda oversized but heh, you can't put a price on free.
First things first I had to drain the table and clean out water table pan. I really need to teach my kids to do this....
I cut some 1.5" x 1.5" x 4" long angle iron that go between the existing slats for stands on each end of the new slats. Since the bottom of my water pan drains to the center of the bottom all new slats had to be fitted in place. I just laid a level across the existing slats and tacked the new slat to the angle iron when it was straight across.
Yes, this was time consuming but heh all I have is time now;) I also had to number each new slat because they are not all same build. I will not be able to flip these but since they are 1/4" I think they will outlast the 1/8" ones I have now.
Adding extra slats
1 post
• Page 1 of 1
Adding extra slats
Post by Billythegoat »
1 post
• Page 1 of 1
Jump to
- ↳ Introduce Yourself
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
