It is currently Thu Nov 22, 2018 5:57 am
Any Cable boom ideas?
Probird
Postby Probird » Sat Dec 23, 2017 3:28 pm
Are they worth having?
Not sure which way to go, will a cable boom be a pain or do they actually work decent....
Anyone built one that works good?
I will be loading sheets with a forklift, so not worried about it being in the way.
4x8 Premier Plasma Table
Hypertherm 45xp
Inkscape
Viacad
Mach3
Proma 150 THC
Re: Any Cable boom ideas?
Postby acourtjester » Sat Dec 23, 2017 4:39 pm
I have installed wire booms an the table I built for the Plasma torch cable only. And for router AC power for a router or air supply for the scribe when switching the torch out.
I used carabiners attached to the cable/air lines to clip on the boom for easy changing. I found a spring and pivot is needed on the end so the boom will flip around when when changing directions. :)
Everlast PM 256 tig
WyoGreen
Postby WyoGreen » Sat Dec 23, 2017 8:08 pm
I use a cable boom to isolate my plasma cable from the rest of the cables in my table cable track. It's just a 10 foot length of 1" conduit bent to the appropriate shape. It's mounted on the middle of the side of my table, and ends in the middle of the table above the gantry. I welded a large washer on the conduit that rides on a ball bearing that is mounted on top of a slightly larger conduit that the 1" conduit goes through on the side of the table. This lets the boom swivel with very little effort. I don't have a picture of the setup right now, but it is somewhat similar to acourtjester's.
My feeling is the boom helps keep noise off the motor and control cables in the cable track.
CNC Router table
steel 35
Postby steel 35 » Fri Jan 19, 2018 8:54 pm
I spent about a week trying to do mine from a corner, before getting the help already suggested
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
Postby acourtjester » Sat Jan 20, 2018 7:24 am
If you have a 8' table it is better to have it in the middle. In the lower picture you can see a pivot arm I used so the boom will be able to change directions with the table. That thing swivels with the cable when you move the torch around the table, the spring keeps it straight when not turning.
The spring is light similar to one on a screen door. :D
Everlast PM 256 tig
IBBruin
Postby IBBruin » Sat Jan 20, 2018 11:30 am
I went with the KISS method. Simple but it works. :D
Darryl
Gorilla 48x48
PM 65
Aspire 9.015
