limit switch wiring
leggman
limit switch wiring
Post by leggman » Thu Jun 23, 2016 8:13 pm
I have been changing breakout boards trying to get the plasma trigger to work and that has been accomplished. But now I cannot get the limit switches to show up in mach3. This is the board I am using
http://www.ebay.com/itm/US-Ship-5-Axis- ... Sw3ydVmzqq
The wiring is all good like before but try as I might I cannot get the leds to light up in the diagnostics page.
I hope someone can help, This is my last hurdle before I start making cuts.
WyoGreen
Re: limit switch wiring
Post by WyoGreen » Fri Jun 24, 2016 10:57 am
Looking at the board diagram, it looks like you should be able to short directly from Gnd on the bottom left of the board to 1 of the 5 inputs above it, which should light a led in Mach3. If not, then you need to look at the setup in Mach3. Perhaps the ports and pins are not setup correctly in Mach3.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
CNC Router table
sphurley
Post by sphurley » Fri Jun 24, 2016 10:42 pm
They show the input settings in the manual
5_Axis_CNC_Breakout_Board_Interface_Users_Manual.pdf
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
leggman
Post by leggman » Thu Jun 30, 2016 12:18 pm
I have 5 volts coming into the board. Do I also need a 12-24 volts coming into it??????
In the specs it says
Input Voltage
USB port from PC and 12-24V power supply.
This has me wondering
leggman
Post by leggman » Thu Jun 30, 2016 1:55 pm
I GOT IT
I hooked a cheap 12 volt power supply ( I think it came from a old phone or something) to the board and it works. For some reason it needed 12 volts to work the input switches??? Now everything works. Time to move on to whats next and that would be setting the torch height control with the touch off switch. It's always something.
Ribbedgiraffe
Post by Ribbedgiraffe » Wed Jul 06, 2016 4:17 pm
Ill be curious to see how this board works for you.. I've been eyeballing it on ebay..
Still learning!
4x8 homebuilt w/Water table - Hypertherm Powermax 45 (Machine torch)
13" Metal Lathe
7x12 Meta lathe
1-1/2hp Milling machine
Hobart 190 Wire feed
Hobart EZ-Tig
Elcheapo powdercoating gun W/Autoclave oven converted for powdercoating.
