Mill Conversion to Plasma cutter.
Re: Mill Conversion to Plasma cutter.
Post by adbuch » Tue Sep 08, 2020 12:55 am
spidey4fun wrote: ↑
Mon Sep 07, 2020 9:57 pm
Thanks for the feedback. I hadnt given much thought where to best place the earth lead. I can see how connecting it to anything other then the pipe might cause arcing issues.
I also run a separate earth ground from the material being cut to an 8 ft. copper clad ground rod driven into the ground located about 10 ft. away from the machine. In the photo, you will notice a large copper lug mounted to the end of the machine support frame. In my case the cable attached with the clamp to the material being cut has the other end attached to this copper lug. I then attach both the earth ground cable clamp and work lead clamp to this copper lug. So this effectively connects both the work lead and earth ground directly to the material being cut.
spidey4fun
Post by spidey4fun » Sun Nov 15, 2020 1:40 am
I've started my next project and this is the first part cut on my DIY plasma cutter..
Greolt
Post by Greolt » Sun Nov 15, 2020 3:22 pm
Looking good Brad.
You have come a long way from cutting spider eyes on the laser. πŸ‘πŸ˜
spidey4fun
Post by spidey4fun » Sun Nov 15, 2020 5:43 pm
Hey Greg. By the time I got to spider eyes I'd learnt heaps. This is where it all started...
I think this is your Milwaukee I used before I purchased my own when the above router broke.
And I have to say without your help, and advise from the very start I doubt I'd be where Im at now. So THANKS!!!!! :Yay
Post by adbuch » Mon Nov 16, 2020 1:53 am
spidey4fun wrote: ↑
Very impressive indeed!!
:Like :Like :Like :Like :Like
spidey4fun
Post by spidey4fun » Wed Dec 02, 2020 7:31 am
First large cut. Im still a little unsure why the Plasma cutter switched off at the end, but recovered the cut easy enough.
spidey4fun
Post by spidey4fun » Sat Dec 12, 2020 6:58 am
This should work.
And my other new little helper. :)
Post by acourtjester » Sat Dec 12, 2020 10:17 am
Well looks like you having fun with DIY projects, and sharing them with us. I built a saw like that years ago and the secret is do not oil the blade while cutting. the oil keeps the swarth from falling away from the metal and gums up the process. Dry is better IMHO :-D
spidey4fun
Post by spidey4fun » Sun Dec 13, 2020 12:05 am
So here's my first attempt to cut a pipe.
A little more fine tuning required but it seems to work. :Yay
Post by acourtjester » Sun Dec 13, 2020 9:53 am
Ah the old third time is the trick :HaHa remember any step forward is a success, little fine tuning and you will be there. :Like
Here is a similar tube cutter I built, I cut and welded up a manual 3 jaw chuck for an easier transfer of power to the tube.
have fun, DIY is alive and well in your shop :Yay
spidey4fun
Post by spidey4fun » Mon Dec 14, 2020 8:08 am
Yes i'd seen your video. It gave me the idea to use the metal braided straps. Thanks.
spidey4fun
Post by spidey4fun » Tue Dec 22, 2020 12:19 am
Some more plasma cutting on my project.
Post by adbuch » Tue Dec 22, 2020 3:13 am
That's another great video!! Please keep them coming.
Greolt
Post by Greolt » Tue Dec 22, 2020 4:36 am
Going great guns there Spidey. πŸ‘
spidey4fun
Post by spidey4fun » Mon Dec 28, 2020 7:44 am
Here's another..
spidey4fun
Post by spidey4fun » Mon Dec 28, 2020 9:11 pm
Here's a quick tutorial on altering a mach3 screen. Thanks for the idea Greg. Hope it's useful to someone.
ralphieboy127
Post by ralphieboy127 » Tue Jun 01, 2021 6:54 pm
Hi There,
I too am using Mach3 (I clicked on every feature there is over the last four years.....LOL) I am also using a floating head with a homemade macro
It works great, I am using the spindle delay feature for my pierce delay with an on screen DRO to adjust the pierce delay, I would like to also put the cut height on an on screen DRO to adjust the cut height (instead of modifying my macro) do you think you could help me with this?
Thank you, Ralph
ralphieboy127
Post by ralphieboy127 » Tue Jun 01, 2021 6:58 pm
Hi There,
Thank you, Ralph
Return to β€œDIY Plasma Table & Accessory Discussion Forum”
Industry Pros use FastCut CNC
