Thermal Dynamics 60i
I was wondering if anybody has thoughts on the cutmaster 60i? I am going to build a table in the near future but need a hand cutter now. Does this unit need the automation interface card like the 52/82? The manual online says there is optional automation cable. Just want to make sure I can use for the table later. Any help or thoughts on this unit is greatly appreciated
Re: Thermal Dynamics 60i
Did you get the the 60i? I’m interested in information on that machine as well.
The "i" stands for (I think) "Interfacer" . It has the internal voltage divider and CPC connector built in but should work fine with a hand torch for hand cutting. The i sereis do not have all of the automation features/options of the Hypertherm 45Xp thru 125 series but at least you don't have to perform Open Plasma Surgery to use with basic CNC controls.
Looks like there is a optional voltage card setup.(AUTOMATION INTERFACE (A-SERIES ONLY) From what I seen in the manual, there is a arc good signal, contactor inside the machine, and says it's a option for basic cnc. (Never seen the machine in person, so just going by net info..)
Problem is, they are giving you a upgraded power supply, and a 15-16 plus year old torch design..Only hope for them is the torch from Thermacut. It should be released anytime now..They have a work around for the Thermal ATC connection.Their nozzle design is excellent, and will supercharge the 60i.. That or something in new consumables from Victor.. (There is a new 9-8214 electrode out now)
I held on to my SL-100-SV torch in case Victor ever gets a clue..
https://www.manualslib.com/manual/13078 ... r-60i.html
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Sorry had a brain cramp. I was thinking of the TD "A" series (for automation) that has the built in interface. You can buy the interface on later models. When Victor took over R & D went out the window.
