Can anyone help me with a trace
GDS Metal Worx
Post by GDS Metal Worx »
I need to try to do this image into a license plate for a customer. I am going to make it 2 pieces. A top plate and a bottom plate. Each will be powder coated and glued together. Is there anyone that can help me out? I dont really need the tire tread, just the letters and the chick
Garrett
Largemouthlou
Re: Can anyone help me with a trace
Post by Largemouthlou »
Can't help at the moment with the trace. Just wondering why your glueing/bonding the backing, Just make a backing tag blank, coat it and it will bolt together with the mounting bolts from the front plate.
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
GDS Metal Worx
I just use a little sika flex to hold them together until the customer can volt it to the vehicle. The two bolts will hold it all permanent,this just keeps the two pieces from sliding around and scratching each other during shipping
patc
Re: Is it ok to post this dxf? Is it copyrighted?
Post by patc »
Would it be ok for me to post a dxf for this? It might be a copyrighted.
Pat
GDS Metal Worx
I don't believe that the image is copyrighted, the owner gave me permission to use it to make her cut file
patc
Post by patc »
I hope this helps you.
Pat
patc
Post by patc »
OOPS, wait a minute! I just took a closer look at that chicken, and it looks like she's brandishing two pistals. Sorry, my mistake, normally chickens only pack one gun. It's very unusual for a chicken to pack that much heat.
Pat
patc
Post by patc »
She should have enough fire power now.
Pat
GDS Metal Worx
LOL Thanks Patc. I can take that and run with it for now. I need to learn how to do a trace sometime...
