Does anyone have a pattern for an engine lift plate?
Thanks in advance
lift plate
lift plate
PlasmaRoute 4X8
Hypertherm Powermax 65
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
Re: lift plate
Hi,
Here is a lift bracket I built. Just weld the two pieces together. I have usd mine severaal times. It is designed for the sb chevy. you can relocate or add holes for others. This is a cut path.
Mike
Mike
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
Re: lift plate
Thanks aicomp!!!
PlasmaRoute 4X8
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
Re: lift plate
Nice work. You are very welcome.
Mike
Mike
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
Re: lift plate
Well, for whatever reason the holes were about a half off on each corner. It was for a 68 GTO so maybe pontiac is different (dont know). Either way I just plug welded the holes and drilled. worked good though.
Thanks again
Matt
Thanks again
Matt
PlasmaRoute 4X8
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
Corel X5
AutoCad 2012
SheetCam
Mach 3
Inkscape
