Jesus cross modern
Jesus cross modern
Click on this link to find some nice svg files. Made this one a little more plasma friendly.
http://123freevectors.com/category/religion/
I use Corel DrawX5 and Plasma Cam. Here's how:
Down load the file you want and then unzip it.
Open Corel Draw - file - new - ok
View - wireframe
File - import - import the file (EPS, SVG, or AI)
File - export - export as a dxf file
Import the dxf file in to Plasma Cam
Dave Hanks
View - wireframe
Dave Hanks
- ctorres3120
Re: Jesus cross modern
very nice and very modern, thanks for the file, Dave
Carlos
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Nice. THanks.
Great job thanks for sharing.
- billyeagley
Thanks, Dave. Thanks for the tip, as well! I appreciate it!
PlasmaCAM 5x10 (Samson) - DesignEdge - Hypertherm Powermax 65
Wife's been wanting a cross cut out,and this looks like a dandy!! thanks for sharing
Plasmaroute HD 4x4 TD A-80
Ha Dave
Thanks for the file. I think I can use this one for the Church new pulpit. Will have to get the Elders approval first if they do I will post the final pictures after I get it finished. Thanks' again Rod
Rod S in AZ
- Larry83301
Thanks. Looks like something that many will want.
You're welcome everyone and thank you to whomever designed this. It's one of the nicest depictions I've ever seen of the crucifixion. The cross behind will be powder coated in copper vein and the Christ will be silver vein.
Dave Hanks
Dave Hanks
That is really nice thanks
Awesome! Thank you for sharing!
Very nice,,, what will you use to keep the backing in place after powder coating?
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- mekanic13
Very nice! Thanks for the file.
WOW Thanks
I tig weld tack SS 10-32 nuts on the back of Christ. Burn holes in the back plate and locate where to weld nuts on. Then I use short 10-32 SS button head screws to hold it together.Largemouthlou wrote:Very nice,,, what will you use to keep the backing in place after powder coating?
Dave Hanks
- MetalheadRK
Great file! Thank you for sharing!
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Hypertherm 45
Thanks,, to date I only have been cutting aluminum.. Don't think I can tig stainless to alum?DXF wrote:I tig weld tack SS 10-32 nuts on the back of Christ. Burn holes in the back plate and locate where to weld nuts on. Then I use short 10-32 SS button head screws to hold it together.Largemouthlou wrote:Very nice,,, what will you use to keep the backing in place after powder coating?
Dave Hanks
Some 3M fender epoxy would withstand the cure cycle though..
Had another thought I may be able to make an aluminum nut and tap it out to 8/32 and tack it!! Hmmmm may work
1250 hypertherm
CandCnC electronics
CandCnC electronics
Thank you! That is really nice.
This one is 46" tall. Almost need a hoist to pick it up!
Dave Hanks
Dave Hanks
I scalled it down to 16" and cut some out of .090 aluminum for Christmas presents.. Will post pics when I get them coated!!
Yours look great!!
Yours look great!!
1250 hypertherm
CandCnC electronics
CandCnC electronics
This is a great looking cross, thanks for sharing.
Here is how mine came out 16 X 21. 090 alum Thanks again for the great file..
Backing is silver graphite and front is gold with mirror clear. Don't show in the picture but there is a 1/4" space between the 2 pces
1250 hypertherm
CandCnC electronics
CandCnC electronics
Looks great!
Dave Hanks
Dave Hanks
- MetalheadRK
Wanted to thank you again for the file and post a picture. We did the back cross in copper and torch and the front cross just in copper. I think it turned out pretty nice.
4x4 PlasmaCam
Hypertherm 45
Hypertherm 45
I like the color scheme. The three I cut are at my powder coater and I'll post pics when they are done next week.MetalheadRK wrote:Wanted to thank you again for the file and post a picture. We did the back cross in copper and torch and the front cross just in copper. I think it turned out pretty nice.
Dave Hanks
