It is currently Mon Sep 24, 2018 7:55 am
PLASMA SKIPPING DURING CUTTING
Burn Tables plasma table discussion forum
tdalechick
Postby tdalechick » Sat Oct 06, 2012 11:41 am
I have attempted about 10 squares redrawn about 5 times with no broken lines and every time my torch gets to cutting good and then it skips. What is causing this problem??? Burn tables has been no help in clearing up this problem for me. I am getting fustrated and I am new to this. Really hoping I can get this problem solved today. Any help would be appreciated.
-I am using a Hypertherm 45 with a burn table with dhc.
cstroke
Re: PLASMA SKIPPING DURING CUTTING
Postby cstroke » Sat Oct 06, 2012 1:09 pm
Try turning your height control off and cutting one.. manually keep your height around 1/8"..
If it cuts then it's a problem with your height control.. This might not be your answer but you can start eliminating problems..
Is your ground hooked directly to the piece you are cutting?
wickedinhere
Postby wickedinhere » Sun Oct 14, 2012 9:52 pm
Low air pressure?
Return to “Burn Tables”
Users browsing this forum: No registered users and 0 guests
