Guantanamo Bay Seal US Navy I Think I Got it
prattswelding
Post by prattswelding »
I need help with a trace of the US Navy Guantanamo Bay Seal. A customer wants a mirror cut out of it. Thanks!
-Brian
prattswelding
Re: Guantanamo Bay Seal US Navy I Think I Got it
After many tedious hours, I was able to get pretty close with the trace I was needing (much to my suprise). I used the rope design from a Marine Corps Seal that I got from this site. Other than that I was able to pull it off with Corel and Plasma Cam (learning as I go). The file isn't 100% cut ready yet, but if someone else needs the design, here's a rough draft. I included some hangers on the file that I use on the backs of clocks and mirror frames to hang them by. Just bend each end down to a 90 about a quarter of an inch up, weld to the back and there you have it. Sorry the file is in a PCM format, I can't export DXF without the $1000.00 upgrade. Hopefully another member on the forum can convert it over and upload it again.
Mirror Guantanamo Bay.pcm
MADMAX99205
Post by MADMAX99205 »
DieselMonkey
Post by DieselMonkey »
Heres the DXF
Mirror Guantanamo Bay.dxf
Few problems in life can't be solved with the generous application of a cutting torch and a taco truck.... or something like that.....
Ryle524
Post by Ryle524 »
nice job looks great
kpj5br
Post by kpj5br »
I'm not sure if I'll cut this for our American Legion or not yet but either way thank you for taking the time to make this and share it!
