How do I get rid of the box around my dxf in Corel Draw
I know this is probably a stupid question. When I export a from Corel Draw it places a box around it kinda like its the page outline that the design is on. Im new to this. How do you get rid of it?
Re: How do I get rid of the box around my dxf in Corel Draw
what format are you exporting, what program is showing the box, did you import anything that might have had a bounding box (that may not be visible in normal view mode)
some formats (like eps) have integrated bounding box attributes, others (like svg) often have a bounding box
for the most part, corel does not add anything out of the blue....
I have not had this problem however I was able to create it by adding a page frame to the document. When I did this a box was added to the drawing. To remove I selected the frame in the original view and deleted. - John
John that helped. Thanks guys.
