tacoma747 wrote:Running Mach 3 software, the control box is from Probotix. The boards that keep popping are in the link below. http://www.probotix.com/stepper_motor_d ... ProboStep/
It has been popping the Y-Axis board mostly, two times when I first got the table as soon as I would try to make a cut replaced the board), then after talking to the manufacturer, they told me to make sure the ground rod going to the grating on the table was attached well, now, so then I attached the ground rod directly to the material I was cutting (with the plasma ground clamp), that seemed to work, I was able to cut a few things out. Now today I was cutting and it blew the Y-axis board again. After swapping the board out, it worked for a very short period and appears to have blew all 3 boards, X/Y/and Z do not work now...
They are mailing me a new control box tomorrow, and told me to try driving another ground rod for the table grating, any other ideas?
tacoma747 wrote:Plasma is a ESAB PCM 875
As for grounds:
Control box is grounded (to the ground terminal)
Plasma cutter is grounded, to the chassis ground terminal
Tables is grounded, connected to the rod that goes through the grating.
All 3 have a separate ground rod. I am going to run another ground rod for the table grating.
I just don't see how feedback or voltage can be going through the motors, the plasma torch is not connected to a 'ground' in any way, the spike would have to be jumping from one insulated wire to another.
OR, I guess maybe the spike could be going through the table grating, through the drive assembly where the gantry contacts the table and back through the drive motors?
Is there anything I can do in conjunction with more ground rods to prevent this?
tacoma747 wrote:Well I bit the bullet and bought a new plasma cutter. I bought an Everlast PowerPlasma 60C, it's specifically made for CNC cutting, got it for $1000 shipped with some extra consumables. Didn't like the idea of a Chinese unit, but it seems most electrical stuff comes from china anyways, and the reviews have been pretty good on them. Plus, a 5 year warranty is good for me. If it lasts 5 years, it would have more than paid for itself by then. I've seen plenty of name brand machines at the local welding supply store that had bad circuit boards, and the boards were too expensive to even bother fixing...
Thanks for the help, now I just hope I can sell this PCM 875, or at least the machine torch I bought for it...
jimcolt wrote:The Everlast units use either high frequency / high voltage start.....or blowback start (non high frequency). Hopefully you purchased the blowback start model...otherwise you may still have the electrical noise issue.
Jim Colt
jimcolt wrote:The system you bought is a high frequency start.....instead of creating a high frequency AC surge to ionize the gas it uses an inductive discharge......which makes almost identical electrical noise as the Esab system. They also have in their product line a "blowback" start torch.....which is more like the Hypertherm Powermax units that do not use high frequency....which would certainly be a better choice to solve your issue.
Good luck with the new system....but I would think that it will perform similarly to the Esab. I have been working with plasma systems for 35 years....I have fought high frequency issues many times!
Jim Colt
cypher wrote:How is the everlast plasma holding up? also I notice there is only one type of consumable how is the cut quality on different materials? could you post some pics thanks
Return to Various Manufacturers
Users browsing this forum: No registered users and 0 guests
