Has anyone ever tryed to use one of the Needle scaler for removing slage on the back of there parts? if not I will go buy one and try it out.
here is a pictures of one.
Needle Scaler for removing plasma slag?
- Attachments
- (5.97 KiB) Downloaded 363 times
- admin
- Site Admin
Re: Needle Scaler for removing slag?
Hey Jim
I have one of these mounted to my workbench and I made a hold down with flatbar that bolts to the bench over top of the needles to flatten them out close to the end. This makes for a wider effective deslagging area. I simply plug the air in, set my part on the bench and move it across the needles around the entire outside of the part. Works good on plasma cut steel parts 3/16" or thicker. Does not work on plasma cut stainless steel or aluminum.
What also works well is a 10" length of 3/8 drill rod or hardened steel with a file handle on one end. Simply run it back and forth along the cut edge and it is a fast and effective means of removing the dross or plasma slag. I find myself using this method more, it's fast, quiet, and easy assuming your parts are cut well.
admin
admin
Re: Needle Scaler for removing plasma slag?
I have one, it works well on parts with alot of small lettering. I use many different ways to remove slag,I just find what works the best for each job.
I use one laid down at a little lower angle than shown in the photo to target just the edge as not to hammer the surface of the plate.
