smoke eatter
smoke eatter
Ok I got rid of the screens around my table and put together a table that holds water so the smokey dust will go right into the water. It have been great no more dust. But i still have a little smoke. Not much but the smoke is still bad. Its winter time now and I dont like to open the doors to much now. I lose all my heat. Is there some kind of smoke eater on the market that I can put up and take care of the smoke and keep the heat in my shop.
Patrick
- plasmajoe
Re: smoke eatter
This is what I use and works great.
http://www.sentryair.com/weldingapp.htm ... KgodFwMZXw
- Zippo
Re: smoke eatter
What i do in the winter, i use a dryer flex hose drop from a 4" pvc pipe with a inlet 4" fan to exhaust. I know cheap. and i simply attach it to the side of my SL100 torch with a zip tie. Since it is centered on the table not had any issues reaching all areas. One draw back even with my water table i still get some dust in the vent system. And it does leave dust outside by the vent clapper. and i have a small shop so my table is fairly close to a wall not having to vent very far
