script
Re: script
Not sure what you were asking? But, I threw this together.
Re: script
Thanks Metal Art but I am looking for it to be done in writing script and the letters wide enough that it can be cut with plasma with out dropping the narrow parts of the script. RON PS: I have not been able to find wide writing script.
Re: script
Okay, how about this one.
Re: script
Metal art,If I was a girl I would kiss you. I think this will work. She wanted a little more scroll in the letters but I think this will make her happy. Thanks again,RON PS: All you guys and gals are teriffic.
Re: script
Metal Art, What program did you use to create this?
Mike
Mike
- Chopper John
Re: script
Hey ron, If I remember right metalart is female.....ron wrote:Metal art,If I was a girl I would kiss you. I think this will work. She wanted a little more scroll in the letters but I think this will make her happy. Thanks again,RON PS: All you guys and gals are teriffic.
Chopper John
Mad City Cycles, Inc.
Re: script
You're right Chopper John, female I is!
Re: script
Oh by the way, I used the Plasmacam program. I downloaded Alko-Bold font and just joined the letters in Plasmacam. Then exported it to a dxf file.
Re: script
Thanks for the reply
Mike
Mike
Re: script
No worries, always glad to help when and if I can! This forum has given me so much , I believe it's only right to give back.
Re: script
metalart , well you better pucker up cause I am sending it your way.RON
Re: script
Hi kentucky farmer.
I don't have plasma cam, but can get the same (kind of) results in autocad. just use the "txtexp" command. This will explode any text, and then you can also add tabs to prevent the inner circle from the "O" fall out etc.
good luck.
good luck.
Re: script
I use sheet cam and mach 3 on table, draw with inkscape and delta cad.
My table is just a old home made thing I trowed together witn candcnc controls.
Thanks for the info anyway
Mike
Mike
