Cutting i/4 inch hot dipped galvanized plate
Dirtmotor
Post by Dirtmotor »
I was digging thru my steel pile for some 1/4 inch plate ,hot dipped galv. 12 inch wide flat iron is all I found .
Never have cut any of it on my table . I am sure the fumes are thick . I do have a water table and a decent exhaust set up . The questions I have is how does it cut and how rough on consumables is it ?
05Duramax
Re: Cutting i/4 inch hot dipped galvanized plate
Post by 05Duramax »
For me galvanized has always cut just as well as mild steel, it will deposit soot on your nozzle and shield but I don't find it is any harder on consumables than mild steel.
Dirtmotor
Post by Dirtmotor »
05Duramax wrote: Mon Apr 15, 2024 12:40 pm For me galvanized has always cut just as well as mild steel, it will deposit soot on your nozzle and shield but I don't find it is any harder on consumables than mild steel.
Thanks , I guess I will dive in and give it a try .
05Duramax
Post by 05Duramax »
Curious how the galv cuts for you. Posts pics of your parts if you can.
