post process
19bensmith92
post process
Post by 19bensmith92 »
hi, I am new to this I have currently just bought a escco plasma table with a hypertherm 105,
before I bought the table to my shop, the bloke I bought it from gave me a quick run though,
now I go the table and everything set up in my shop I cant seem to post process. i can add a new part and then i add the operations and then it wont post process nothing happens
any help would be great
weldguy
Re: post process
Post by weldguy »
What software are you working with?
19bensmith92
Re: post process
creating the DXF files using solidworks then placing them into SheetCAM TNG to create the .TAP file but i cant post process
Re: post process
After you have created the operation (cut operations) then you go to the file drop down menu, the first line is post processor. If you have selected a post processor under the operation drop down menu it should generate a G-code and give you a place to select where to store if (folder location).
Start with one item to cut like a square of circle to learn the procedure, then move on to more items in the plan.
19bensmith92
Re: post process
i get to the part where i go to the file drop down menu and post process but i keep clicking it and it does nothing. doesn't give me to file location page.
if i do the post process before adding a cut operation it will let me post process and save it but i haven't got a cut path
Re: post process
19bensmith92 wrote: Wed Mar 27, 2024 4:10 am i get to the part where i go to the file drop down menu and post process but i keep clicking it and it does nothing. doesn't give me to file location page.
Perhaps post the particular dxf file you are working with so one of us can run it thru Sheetcam and provide you with the g-code file.
19bensmith92
Re: post process
thanks for the help i guys i found if i save the job after doing the cut ops and reopening the job i can post process then and all working well
Cheers
weldguy
Re: post process
Post by weldguy »
19bensmith92 wrote: Wed Mar 27, 2024 9:23 am thanks for the help i guys i found if i save the job after doing the cut ops and reopening the job i can post process then and all working well
Cheers
That's great, thanks for posting your solution :Like
Re: post process
Here are some other things that may help. The cut oath display can be turned on/off and you can run a simulation of the cutting operations.
Return to “SheetCam”
