Hey yall. I'm happy I found this forum. I operate a huge commercial plasma table for my 9 to 5. Hopefully I'll have a table in my own shop soon.
I'm going to try out some of these files on the big table but I'm not sure it'll do fine detail. We'll see!
Yo!
- Joe Jones
Re: Yo!
Hi. Which "big table" are you using? What software? What do you normally make with this big table?
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Re: Yo!
The table is Hornet systems. It's a 10'x40' with a hypertherm plasma. I'm not sure what software is on the controller, its very simplified. Any complex shapes get drawn by the draftsmen and I load the template to the machine.
I do a lot of semi truck frame rails, pressure tanks, water towers, and a ton of wear liners for things like dump trucks and loaders. I cut every thickness from 16 gauge all the way to 2.5". The table has interchangeable heads from 35amp to 400amp, I think it'll go to 800amp but the most we do 400
Re: Yo!
One thing to watch is the nozzle size, for finer detail on thin metal most use a fine cut nozzle and lower amps. On a large industrial table they may not be using smaller nozzles. Many cheaper Plasma unit don't come with small nozzles, many are changing due to the small shops and detailed work being done. This can be show in the manuals cut charts showing metal thickness and lower amps, listing the kerf widths.
Re: Yo!
there are 2 separate parts the fine cut nozzle and the fine cut shield, and I think maybe a electrode that works better with fine cut.
